Thread: Coolant level/temp indicator
  1. Coolant level/temp indicator
    Aug 2008
    Hi there everyone
    just after a little advise again. recently the coolant level/temp con has beening coming on. its in red and only seems to happen when the engine is cold (first thing in a morning)
    it will stay on for perhaps 20 mins of driving then go out. the level of coolant is fine and the system has no leaks. the operating temp is stable at 90*.
    seems to me that it may be a fault sensor but does anyone know which one is favourite??? (1.8t engine code AEB)
    cheers.................... mark
  2. Re: Coolant level/temp indicator
    Jun 2007
    I'm not sure what you mean "coolant level/temp con " con what is con. First thing to check is the header tank level sensor connector. Regards Peter
  3. Re: Coolant level/temp indicator
    Aug 2008
    hi
    sorry that should of read "icon"
    i have checked the connections of the level switch in the header tank and also the temp sender in the bottom radiator hose, all seems ok!!
    cheers........... mark
  4. Re: Coolant level/temp indicator
    Jun 2007
    The temp sender is at the rear of the engine with a 4 pin connector. It has two elements to it one for the ECU, one for the guage. The sensor in the bottom hose is the two stage cooling fan switch. Regards Peter
  5. Re: Coolant level/temp indicator
    Oct 2007
    Remove the connector on the coolant shortage indicator switch F66 on the header tank.Bridge the 2 connectors,if the fault is rectified,replace the tank.
  6. Re: Coolant level/temp indicator
    Aug 2008
    kenney
    linked out switch f66 and as you say the fault has cleared and not returned!!! any ideas of a price for a expansion tank??
    many thanks ............. mark
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. 1997 a4 indicator constant clicking
    By Quatty_McQuatt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2010, 01:40 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. What is the safest way to dispose of old G12 Coolant ?
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 03:38 PM
  5. Coolant system renewal!
    By Pernicitus in forum Golf MK3 - 1993 - 1999
    Last Post: 22-10-2007, 11:39 PM
