Thread: fan running continously 2.5 v6 tdi... thermostat or what ??
Results 1 to 10 of 10
  1. Thumbs up fan running continously 2.5 v6 tdi... thermostat or what ??
    May 2009
    edinburgh
    Hi there newbie here - could do with some help with the a4 i have just bought......
    Fan comes on immediatly at startup and never switches off (not aircon fan). It is not a viscous fan, it is an electric fan.
    The Temp on gauge stays about 60 unless on a drive it goes up to 65. The climate control codes for 49 (coolant temp)say 60 degrees and 51 (engine temp)says 90.
    I have just replaced the ect sensor and it made no difference at all - could it be the fan switch or relay sticking, or could it just be the trusty thermostat ???
    There are no warning lights
    In advance , thanks for all input
  2. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    134 Post(s)
    1995 Post(s)
    Year and engine code?
  3. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    May 2009
    edinburgh
    apologies, it is a 1999, engine code AFB
    cheers
  4. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    134 Post(s)
    1995 Post(s)
    So you mean the smaller fan on the right hand side of the radiator, not the larger viscous coupled fan?
  5. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    May 2009
    edinburgh
    Damn i am stoopid - it is the viscous coupling fan.....
    does it mean the fan is goosed ??
  6. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    134 Post(s)
    1995 Post(s)
    This set up changes in 99 according to chassis number, is your chassis number before wauzzz8DzXN199999 or after?
  7. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    134 Post(s)
    1995 Post(s)
    No, the fan should windmill all the time, you will be in no doubt should it kick in, the roar and air rush from the bay is unmistakable!
  8. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    May 2009
    edinburgh
    chassis number is
    this forum rocks !!! thanks for all the help mate
  9. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    May 2009
    edinburgh
    puts my mind to rest over fan issue then ..... cool
    do you think it is the thermostat then ?
  10. Re: fan running continously 2.5 v6 tdi... thermostat or what ??
    134 Post(s)
    1995 Post(s)
    No problem, I don’t need the chassis number now as I don’t think I need to look up the relay numbers for you to start pulling them out. Delete your chassis number now.
  1. Change from 5sp to 6sp
    By lowndsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 08:14 PM
  2. Buying help for A4 2.5 TDI quatto newbie
    By tom4motion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2007, 09:24 PM
  3. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  4. Replies: 0
    Last Post: 20-07-2005, 08:45 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
