Thread: A6 ABS pump problem?
  1. A6 ABS pump problem?
    Mar 2007
    New on this forum looking for advice. I recently took my A6 in to my local non Audi garage for it's annual MOT. After parting with £200 for the MOT a new CV gator cover & a new switch for the fog lights I drove the car home. When I approached the 1st junction I braked and got a really annoying sprining noise along with vibration from the brake pedal all at very low speed, when the car comes to a stop it seems to pull to the left.
    I asked the garage about this and they say it's the ABS pump, however it should clear itself. A week on and it's still the same, are the garage covering up a mistake they have made? They say they put it on the computer and eveything checked out no warning lights on the dash etc. My other concern is is this dangerous? as I have 2 small children.
    Please help!!
    John
    Mar 2007
    Yorkshire
    Quote Originally Posted by A6 John View Post
    Please help!!
    John
    Pulling to one side and making ABS nosies/actions, I should say its dangerous. Get it to a garage quick, or better still, get them out to you.
    Are you a member of a breakdown company?
    sounds like they made an **** of something when they did the cv gator.
    Take it back and make them fix it.
  4. Re: A6 ABS pump problem?
    Sep 2007
    I've just had my ABS ECU back from being repaired and my A6 is doing the same...
    Did you find out what was wrong with yours John?
  5. Re: A6 ABS pump problem?
    you need to clean your abs speed sensors (one each wheel). Very easy thing to do and costs nothing if you do it yourself. They just pull out and you clean with some favorite stuff like krake parts cleaner. Easy to tell where they are since its the only electric wire going to the wheel.
  6. Re: A6 ABS pump problem?
    May 2007
    knee deep in clunge
    14 Post(s)
    sounds like the abs sensor or the ring gear on the cv joint has been damaged,also the wiring may have been damaged at the time of repair.
  1. VW Transporter 1993 Injection pump timing belt problem.
    By Bambiboy in forum The Commercial Range
    Last Post: 28-05-2009, 02:21 PM
  2. oil pump
    By muffin in forum Audi A4 - Archive Topics
    Last Post: 29-05-2007, 03:51 PM
  3. A6 2.5 TDI sounds like bag of spanners (fuel pump problem?)
    By acetaylor in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-04-2007, 03:48 PM
  4. water pump
    By garying3980 in forum Passat - Archive Topics
    Last Post: 27-02-2007, 06:34 PM
  5. ABS Pump
    By viffermark in forum Polo - Derby - Lupo - Fox
    Last Post: 08-03-2006, 05:01 PM
