Thread: Audi A4 B8 - VAG.com Tricks
Page 43 of 44 FirstFirst ... 3341424344 LastLast
Results 421 to 430 of 435
  1. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2009
    Kidderminster
    There is so much you can do. I personally think the most useful ones on my car have been:-
    1) Activation of beep and double beep when opening locking the car
    2) Setting the ADS to default to Individual.
    3) Activating TPMS without any new hardware being needed (correct ABS unit needed)
    4) Setting the steering angle sensor calibration.
  2. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2014
    A, A
    ADS and TPMS and what does the hidden menu provide?
  3. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2015
    Lincolnshie
    Hi new to the forum anyone got vag com near Cleethorpes.?Great forum by the way...
  4. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2014
    Leicestershire
    19 Post(s)
    Thanks to all for the (many) pages of info here!
    Got my cable today...
    Needle sweep
    Headlights on with get home/leave home
    Mirror dip on reverse
    Window roll up/down on long key fob press
    Also reset my service indicator that my local garage couldn't do after my recent service!
    Ready for mods in Leicester if you need.
  5. Re: A6 C7 VCDS Tricks
    Feb 2014
    Leicestershire
    19 Post(s)
    I've made a problem on my B8 with trying the TPMS.
    Anyone else tried to enable it and got a TPMS fault up straight away?
    This is te code I used:
    [03 - ABS Brakes]
    [Security Access - 16]
    [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
    [56 - Radio]
    [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 6 - TPMS Settings active
    [17 - Instruments]
    [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
  6. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2014
    Leicestershire
    19 Post(s)
    Found my own issue...
    Operator error!
    The system was activated correctly, it just needed the base setting accepting in the car menu.
  7. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2011
    Kent UK
    Does anyone know if it's possible to programme the turning lights (the ones that come on at low speeds with the indicators and steering past a certain angle) to come on with main beam? Also, can this be done for the foglights too? Car is a 2012 B8.5 A4 Allroad with Xenon's. Thanks.
  8. Re: Audi A4 B8 - VAG.com Tricks
    Jun 2015
    Sheffield
    Mate what kit did you get that help you do this?
  9. Re: Audi A4 B8 - VAG.com Tricks
    Ardfern
    8 Post(s)
    The answer may be in this thread, but please could someone let me know if these mods also work for a B8.5?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  10. Re: Audi A4 B8 - VAG.com Tricks
    Jul 2007
    Hi, anyone in Leicester are near by that can do these mods to my car? Audi A4 2013.
    please let me know.
    thanks
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
