Thread: Audi A4 B8 - VAG.com Tricks
Page 42 of 44 FirstFirst ... 324041424344 LastLast
Results 411 to 420 of 435
  1. Re: Audi A4 B8 - VAG.com Tricks
    46 Post(s)
    No need to write down the original code as VCDS keeps a log of all coding and adaption changes in the program directory.
  2. Re: Audi A4 B8 - VAG.com Tricks
    Jun 2013
    Liverpool
    For the 3 seconds it takes to take a quick pic of the phone better to be safe than sorry i think i done it the weekend and the module done all of what i needed it to do when i clicked no
  3. Re: Audi A4 B8 - VAG.com Tricks
    Dec 2010
    Aberdeen
    did a quick googly and found this so answered my own question
    http://ross-tech.com/vcds/tour/adaption_screen.html
  4. Re: Audi A4 B8 - VAG.com Tricks
    Aberdeen
    63 Post(s)
    Anyone managed to get the automatic tailgate to close with the key fob. Played about on my wife's A4 but VCDS is asking for a security code and it is not appearing in the bubble as normal. Tried 12345 which works for the A6/A7 but no joy on ours.
    Cheers, Scott.
  5. Re: Audi A4 B8 - VAG.com Tricks
    Apr 2013
    Kent
    Enable Independent Fogs control with high beams
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    does the above allow the foglights to be linked to full beam?
  6. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2014
    A, A
    Just noticed this thread and wondering if these items work on all models. Have a 2013 Black edition and curious on the sweeping needles and what the hidden MMI screen is
  7. Re: Audi A4 B8 - VAG.com Tricks
    Aberdeen
    63 Post(s)
    The sweeping needles definitely works on a 2013 as I have enabled it on my wife's car. The hidden menu should work although I didn't bother for her car.
    Quote Originally Posted by Stuarta99 View Post
  8. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2014
    A, A
    Quote Originally Posted by Scott K View Post
    hmmm, might have to get my Audi mechanic friend around. What is the hidden menu though?
  9. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Hi all,
    I don't suppose there is a "VAG code" or some other setting to make the NAV default to "Map mode" when it is switched on?
    Currently when NAV is switched on, it always starts in "Destination" menu, prompting the user to enter a destination, you can enter the "Map view" by pressing the lower right button, but is there a way to get the NAV to always start in the "Map view" mode?
    Thanks in advance
    I guess I should also add that my NAV is the 2G MMI HIGH and my car is a A4 Avant 58reg (2.0TDI S-line)
  10. Re: Audi A4 B8 - VAG.com Tricks
    Jul 2012
    United Kingdom
    Got some tweaks done to my car (Awesome GTI did them for free as part of service :-))
    - Hidden Menu
    - Needle sweep test
    - Battery meter (shows 100% so not sure if works)
    - Lap timer / oil temp
    - Emergency Braking lights - lights flash when braking hard. (went for this one over emergency braking indicator lights)
    - Rip Audio CDs - This options shows but doesn't seem to work as I've tried an Audio CD cannot find tracks on jukebox??
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
