Thread: Audi A4 B8 - VAG.com Tricks
Page 37 of 44 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 435
  1. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2010
    Huddersfield
    Hi Everyone
    I've set my mirror to dip, and it does move, but with hardly any movement at all. To the point where if you weren't looking you wouldn't realise it had moved, which makes it a bit pointless for me at the moment!
    Does anyone know where I'm going wrong or if there is a setting to change the degree of movement?
    I'm aware you need memory features to have it working perfectly, but from what I could pick up people were saying it didn't move back to the right place, not hardly move at all like mine. Car is a 2008 se
  2. Re: Audi A4 B8 - VAG.com Tricks
    Feb 2013
    Gloucester
    57 Post(s)
    When in reverse, use the control you use to set your mirror position to set the dipping mirror to the level you want it to dip to. Then drive off and it will reset itself to your driving position. Stop and put it back in reverse and it will go to the position you just set.
  3. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2009
    Essex
    Mitchy - you need Memory seats to store the postion. Activating the dip for non-memory seats gives a default dip position.
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  4. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2010
    Huddersfield
    Thanks for the replies, I'm not too concerned about them moving to an exact place, just the fact they hardly move at all, I would be happy with a default dip position, but no matter where the mirror is held it only moves a few mm either way
    I have taken this video to prove what I mean (excuse the bad quality, had to do it on low res as out with no wi fi). I have done it parked up, putting the dial back he centre for it to move back, the long movement down is me holding it down, but no matter where it starts from, it only adjusts slightly with reverse.
    I know you are supposed to drive off etc, but obviously this is the only way I could film it, and driving off seems to have the exact same effect as moving the dial for reset it in that it only moves ever so slightly.
  5. Re: Audi A4 B8 - VAG.com Tricks
    46 Post(s)
    Video is private
  6. Re: Audi A4 B8 - VAG.com Tricks
    Nov 2008
    Beverley East Yorkshire
    The video is in private.
    Unauthorised commercial link removed as per forum rules
  7. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2010
    Huddersfield
    Can you try now? if that isn't clear enough, I do have a higher res version I can upload when I get home
  8. Re: Audi A4 B8 - VAG.com Tricks
    Nov 2008
    That seems about right (the first movement) is all I get too.
    How did you enable the belch with vcds :lol:
  9. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2010
    Huddersfield
    lol it was a cough, tried to edit it out.
    Here's a better quality if it helps, just seems if it moves so little there isn't much point? it doesn't really help that much with such little degree of movement
    Mirror Movement 2 - YouTube
  10. Re: Audi A4 B8 - VAG.com Tricks
    Nov 2008
    On the clearer version I can see what you mean.
    Have you double checked your before and after long code?
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
