Thread: Help - No brake lights
  1. Help - No brake lights
    Feb 2009
    Can anyone help please, I have a 96/97 Sharan TDI with no brake lights, both the warning lights are on in the dash & I have changed fuse & bulbs to be sure, but still no brake lights. Any ideas would be apprecaited
    Just before this happened it appeared that I had to press down hard on the pedal for them to work
    Not sure if its relavant but I had the intermittent glow plus warning sometimes that would disappear once I pressed the brake pedal reasonably hard.
    thank you
    Mark
  2. Re: Help - No brake lights
    Feb 2009
    sorted, brake light switch!!! £4.25, easy done!!
  3. Re: Help - No brake lights
    Jun 2009
    Dorking Surrey
    I have the same problem you had, where is the switch can I get one from Halfords?
    If you can help
    Helen
  1. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  4. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
