Thread: not turning over - now starting but dying immediately
Results 1 to 10 of 11
  1. not turning over - now starting but dying immediately
    i've been having problems the last week 50% of the time it wont even try and turn over, no clicking or noises from starter motor, absolutely nothing but battery ok.
    now it changed to firing up straight away but dying immediately.
    are these likely to be 2 symptoms of the same problem or 2 different problems.
    if the same problem why has it changed from no starting whosoever to starting but dying!!
    any thoughts much appreciated
  2. Re: not turning over - now starting but dying immediately
    Dec 2008
    Stockport
    Assuming everything else on the ignition side is OK, my thought is ignition switch. They are known to "wear out" and give this sort of problem on Golfs (and I think Polos? cos it's the same part). The start and then die immediately sounds like the immobiliser transponder which, IIRC sits on top of the ignition switch but I can't remember if the power for it comes off the ignition switch. See what other opinions you get before you go pulling the steering column apart to replace it because it's not the easiest job.
  3. Re: not turning over - now starting but dying immediately
    Do you have an after market alarm fitted
  4. Re: not turning over - now starting but dying immediately
    Quote Originally Posted by kenney View Post
    no alarm but have an aftermarket immobiliser (autowatch 239ti)
    back to the original non-start at lunchtime initially but then fired up no problem after a few attempts...
  5. Re: not turning over - now starting but dying immediately
    I don't know the wiring diagram for the 239ti,but if it is connected to the starter then it would be my first suspect. I don't understand why you need two immobilizers,though.
  6. Re: not turning over - now starting but dying immediately
    Dec 2008
    Stockport
    Did the earliest Mk3s have immobilisers as standard? The OP hasn't actually said what car he has IIRC. Otherwise I agree with you though
    According to the OPs other posts it's a 97 AGG 8v GTi, so that should have an immobiliser as standard surely?
  7. Re: not turning over - now starting but dying immediately
    Quote Originally Posted by BobProperty View Post
    every insurance company i've used (and i've used a lot) require a thatcham category 2 immobiliser on a golf gti.
    so that's why it has 2 immobilisers
  8. Re: not turning over - now starting but dying immediately
    Dec 2008
    Stockport
    Quote Originally Posted by hornetcarp View Post
    AHA! Bit of an oversight by someone at VW maybe? Mk4s are OK, Mk3s aren't?
    http://www.thatcham.org/security/pdf...gerCarCAT2.pdf
    Back to the problem. How long has it been installed? Any chance the installer could re-check it?
  9. Re: not turning over - now starting but dying immediately
    it was fitted when i purchased the car in june 2001!!!
    starting problems must be the most common problem on mk3 golfs, searching any forums uncovers so many people with similar problems.
    sods law dictates that there seems to 101 different things that can be the cause....why is life so difficult!!!
  10. Re: not turning over - now starting but dying immediately
    I think the immo was standard from1995. Any of the aftermarket immobilizers i have worked with have been connected to the starter or the fuel pump.From your description of the problem I think for some reason you have 2 issues.One, the starter circut,and 2 the original immobilizer,
  1. Starting Problems
    By blergo in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 07:00 PM
  2. cold starting problem
    By Parkko in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-11-2007, 02:16 PM
  3. Golf TDI injection timing - starting problem
    By Robble in forum Golf MK3 - 1993 - 1999
    Last Post: 19-11-2007, 06:05 PM
  4. Golf 1.9TDI starting problems
    By Douglas.Oshea in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 07:45 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
