Thread: Fuse No 5 Keeps Blowing
Results 1 to 10 of 14
  1. Fuse No 5 Keeps Blowing
    Sep 2007
    Plymouth
    Last weekend I had an oil sensor warning come up in conjunction with the outside temperature read out going haywire. The heating/climate control system also packed up.
    This lot all runs through fuse no 5 which was blown. I replaced today and fuse has blown again, but not instantly. I think it went after trying the climate control.
    I'm rubbish with car electrics. Would this be a vag-com job to see if any fault code comes up relating to the fan flap sticking, or more likely a short somewhere?
    The nearside headlamp is also not working, however, I think this runs another circuit and is perhaps just coincidence that the bulb has blown?
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  2. Re: Fuse No 5 Keeps Blowing
    And the car is ???????????????? Is that a 10 amp fuse. and what is your engine and gearbox code. Regards Peter
  3. Re: Fuse No 5 Keeps Blowing
    S5 protects many cct's in the car mostly disply type functions in cluding the A/c Memery Mirros, folding mirror adjustment all sorts of thing and even the autobox interlock, so as much information as possible please. Regards Peter
  4. Re: Fuse No 5 Keeps Blowing
    First thing to check is the A/C compressor pressure regulating valve on the compressor body. The cable going to this may be chaffing and shorting out, I had one of these a few months ago. Regards Peter
  5. Re: Fuse No 5 Keeps Blowing
    Sep 2007
    Plymouth
    Peter
    1.9tdi AWX 2003 and yes it's 10amp.
    I'll check that suggested cabling first and report back shortly.
  6. Re: Fuse No 5 Keeps Blowing
    Gear box code ??? Regards Peter
  7. Re: Fuse No 5 Keeps Blowing
    Also check the cabling to the HP A/C switch. This may heve been disturbed the last time you changed the timing belt. Regards Peter
  8. Re: Fuse No 5 Keeps Blowing
    Sep 2007
    Plymouth
    I'm no further forward with this yet.
    Had a garage take a quick look this week - they popped in a 15amp fuse, but that blew after the climate control system kicked in. They suggested trying a 20 amp next time! Their diagnostic gear wouldn't communicate with the air con ECU - not sure what this points to yet....but it wouldn't comm with it if the fuse is blown anyway would it?
  9. Re: Fuse No 5 Keeps Blowing
    I suppose put a 20 amp fuse is a good idea so you can identify what is wrong as that is where the fire will start. Dumb Idea. When you say it blew when the climate control kicked in, do you mean that the A/C powered up OK but but when you selected non econ i.e. cooling on, then the fuse blew. If so then I suspect the regulator on the compressor body as I said previuosly. Regards Peter
  10. Re: Fuse No 5 Keeps Blowing
    Did you find any resolution to this problem? as I've an identical problem on identical model/code.
  1. Instrument cluster fuse Keeps blowing
    By mm#2 in forum 80 - 90
    Last Post: 06-05-2009, 11:30 PM
  2. 1996 Polo blowing fuse 21 (interior lights and locking)
    By GavHT in forum Polo - Derby - Lupo - Fox
    Last Post: 24-11-2007, 04:46 AM
  3. A4 95/96 Engine Management Fuse blowing
    By PClements in forum Archive posts
    Last Post: 01-11-2007, 09:46 PM
  4. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  5. BORA fuses blowing ? Which fuse how many Ampere ?
    By henri in forum Bora - 1998 - 2005
    Last Post: 22-02-2006, 11:23 PM
