Thread: TDI Exhaust
Results 1 to 10 of 14
  1. TDI Exhaust
    Mar 2007
    Yorkshire
    Guys & gurls, Ive looked all over the internet for TDI exhausts, something that makes it sounds loud.. but i cant find anything. is there ANYTHING out there for diesel?
    Wouldnt mind a Dump Valve, Although heard these dont work correctly on TDI any how im i correct thinking so?
  2. sound
    Jul 2007
    if you want sound, cut your pipe off at the rear of the cat, use a chisel and drill or whatever to punch out the cat. once you clear the cat(turn the car over to clear the cat, do this over and over till its all out.) have a shop bend you a 6.35 cm exhaust, remove your muffler. the last bend at the tip should point towards the ground. with this set up you will have a blow off sound every time you shift, its a natural diesel sound. if you take out the cat its loud. if you leave the cat in, its not as loud. but the sound is nice not wimpy not a stupid sound, the gas powered vw's love the sound they want to know what kind of muffler it is! My tdi sounds like a bruiser, any questions let me know.
    Mar 2007
    Yorkshire
    Hi sorry... What is the cat and where abouts would i locate it. what does it look like??
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    The cat is a FAT bit on the exhaust, usually only about a metre or less from the engine. The above system is essentially what I have - Mine's a big turbo, good remap - 2.5" downpipe, 2.25" pipe to an oval tail. Have a listen to this video - It's my little oil burner making the exhaust noise at the end.
    http://s58.photobucket.com/albums/g2...hris_mpeg4.flv
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Mar 2007
    Yorkshire
    I see you have a Skoda Fabia VRS which i understand is a 1.9 Diesel.
    Do you know anywhere i can buy Muffler tips? or anything that gives it a good mean noise?
    I dont right fancy getting my chisel and bits out on my exhaust pipe unless i really have too.
    May 2006
    The noise comes from reomving silencers. The cat and all other exhaust fittings like the backbox and middle silencer/s all act to muffle the noise. A straight through pipe is the only way you're going to get a noise even close to my video above.
    I got mine done at a custom exhaust place and they only charged me £300 for the complete downpipe to tail 2.25" pipe, and the tarty oval tail. Most of the cost was labour for them to bend the exhaust to follow the oem path. It really is cheap.
    "chiseling" bits out is the only way you can mod your exhaust for the better, and don't worry about MOTs either.
    Mar 2007
    Yorkshire
    Ah right, So im assuming it would pass the MOT too...
    Well i dont have the knowlegde to do it my self so i will contact a garage and see if they will do it for me..
    Thanks for the info though.
    Oh, Before i go Does anyone know if i can get a K&N Air filter for my car its a polo TDI 2004 model
    Removing the Silencers from my exhaust.. does it in any way affect the power/acceleraton?
    Jul 2007
    Quote Originally Posted by s0niX View Post
    Ah right, So I'm assuming it would pass the MOT too... POSSIBLY
    Well i don't have the knowledge to do it my self so i will contact a garage and see if they will do it for me.. THEY MIGHT NOT PUNCH OUT THE CAT. BUT IF YOUR NOT GOING TO DO TOO MANY MODS HAVE THEM CUT IT AT THE REAR OF THE CAT THEN 2.5 TUBE BACK. IF YOU PUT A MUFFLER IT WONT SOUND GOOD. TRUST ME YOU WILL BE HAPPY.
    Removing the Silencers from my exhaust.. does it in any way affect the power/acceleration?
    IT ONLY GETS BETTER!!!
    May 2006
    #1 rule for TDI exhausts - don't worry about back pressure. TDI turbos produce more than enough on their own so the best exhaust is one which is the most freeflowing possible. The most freeflowing possible is one with no fittings for the gases to whirl around in. Turbo, to downpipe (preferably big) to a decently wide enough pipe, out to the tail. Mine goes straight out rather than down, and I never get a sooty boot because the exhaust gases come FLYING out the back so fast.
    PS: Mine's not a vRS, it's a pd100 TDI which has had a bit of work done to it.
    Mar 2007
    Yorkshire
    Thanks Guys. You help has been great.
    And ur car fooled me.. looks like a VRS
    A post to all u experts...
    If any of you live round the west yorkshire area and u have a better understanding of cars and wish to help me out i would be greatfull and im willing to put my hand in my back pocket and pay you as a thanks
    Cheers again guys, you been great.
  1. To exhaust or not to exhaust, that is the question!
    By nickynibbles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2007, 09:31 PM
  2. Noisy Exhaust!!!
    By rottenronnie in forum Passat - Archive Topics
    Last Post: 30-03-2007, 07:45 AM
  3. exhaust
    By ffcol68 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-10-2006, 08:56 PM
  4. R32 EXHAUST
    By leethe daddy in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2006, 09:49 PM
  5. gt2 exhaust
    By TomLaw in forum Scirocco - Corrado
    Last Post: 29-11-2005, 07:09 PM
