Thread: Juddering on idle
Results 1 to 10 of 28
  1. Juddering on idle
    May 2009
    Essex
    Hi all, I have just traded my 2001 1.8t Golf for a 2.0 tdi Passat.
    When the engine is at idle speed after a min or so the car will start to judder for about 20 seconds then stop. It will do this repeatedly until I drive away. I have tried pushing the clutch pedal and applying the handbrake however neither seem to have any effect. It also does it at all running temps. It does stop if I press the accelerator to slightly increase the revs.
    The car drives normally and I am a little confused as to what could be causing this. Any ideas?
    Thanks,
  2. Re: Juddering on idle
    lorriman Guest
    Mine too. It doesn't do it everytime I pull up and put it into neutral, but quite a lot. It seems to me that it's because the engine isn't idling smoothly. I had this problem with a previous car (2.5l petrol) and the manufacturer finally fitted new engine mountings. Problem solved.
    I'm going to mention this at the next service, whenever that'll be. I suspect the engine isn't running smoothly.
  3. Re: Juddering on idle
    Manchester, UK
    This is a much discussed topic on here.
    I have a 2.0TDI Passat and i find mine does it when the oil level is getting low.
    I top it up to the top of the (very very hard to read dip stick) and the slight judder does go away.
    I may actually be completley off track and my engine may fall apart at any time, i am certainly no mechanic, but the above does seem to work on mine. it has now done 25K (me from new) miles and never missed a beat.
    I have also had a conversation with a tech at our local dealer and he said its nothing to worry about its a trait of that engine.
    Good luck with the new car hope you enjoy
  4. Re: Juddering on idle
    lorriman Guest
    Quote Originally Posted by The Fingers View Post
    Interesting. I must check the oil in mine.
  5. Re: Juddering on idle
    Quote Originally Posted by lorriman View Post
    And mine!
  6. Re: Juddering on idle
    Apr 2007
    France
    12 Post(s)
    ......... its a trait of that engine.
    If we're talking manual boxes here, there must be something wrong with mine then because it doesn't do it.
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Juddering on idle
    I sometimes get a slightly lumpy idle, but never a stall. Can't seem to pinpoint a common scenario when it does it. I wondered last week whether it was doing it because one of the front wheels was in a dip on the drive! (Can't see any logical connection there!)
    (2.0TDi 140)
  8. Re: Juddering on idle
    I get a bit of random vibration at idle occassionaly, as if it's not idling properly, and look down expecting to see some movement on the rev counter, but it's as steady as a rock.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  9. Re: Juddering on idle
    May 2009
    Essex
    I guess the only way to check whether it idleing properly is to hook it up to vag com or something? I don't reallly want to pay VW to do this. The symptoms are exactly the same as described in other posts above.
    Thanks for your help everyone.
  10. Re: Juddering on idle
    Norfolk
    If the duel mass flywheel is on the way out it can put the whole engine out of balance so it seems to shudder on tickover. If this was the problem you would feel it through the clutch as you went to pull away in first gear.
  1. re Fast Idle persists after TBA etc Polo 1.0l
    By patrickLL in forum VCDS - Help Requests
    Last Post: 23-04-2009, 02:10 PM
  2. 03 Polo 1.4 FSI Juddering when idle
    By lpdkill in forum Polo - Derby - Lupo - Fox
    Last Post: 04-05-2008, 04:19 PM
  3. Erratic idle A4 Quattro - 1995- 2.6
    By JDA in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 07:49 PM
  4. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
