Thread: Unit Injector Torques
Results 1 to 10 of 12
  1. Unit Injector Torques
    Aug 2007
    Hi
    Has anyone any experience of tightening the above ?
    Haynes gives 12NM first followed by 270 degrees and I am advised to use new bolts. My engine code is ATJ
    My garage tell me that they are worried tighteing by this anmount and have sheared the injector clamp bolts on a previous VW.
    But as I had an injector come loose I want to make sure it is right this time.
    Any experiences - good or bad would be appreciated
  2. Re: Unit Injector Torques
    Norfolk
    The figures are correct and you use new bolts. That's just how it is done.
  3. Re: Unit Injector Torques
    Aug 2007
    thanks Martin
    The reason for re-doing it is that the head rebuilder did not use new bolts and so that is the reason I am assuming for one coming loose now.
    I want it done right this time ! But I am also wary of the garage disowning responsibility if it does shear.
  4. Re: Unit Injector Torques
    132 Post(s)
    1980 Post(s)
    When an injector comes loose, it always wrecks the head in my experience. Get them to check these areas.
  5. Re: Unit Injector Torques
    Aug 2007
    Thanks Crasher.
    I feared that it might be the case.
    The car covered 1500miles between rebuild and stopping and so I hope that I may be lucky.
    I have just got the car back from the engineers with the injector removed and the insert in place. I can see some scuffing on the body of the injector where it has been sliding up and down against the locations you indicated. The formerly dark colour of the surface is scuffed away to bright metal.
    The O-rings are as expected damaged too but the retaining shoulders for the o-rings seem to be OK.
    I will check the locations you indicated for ovality - but I don't have any dimensions for reference to check for wear. Awaiting a copy of elsawin and so if it is in there any references are welcome.
    The heat shield and retaining ring seems to be present on the injector still and so have not disintegrated and fallen into the cylinder as I wondered.
    Otherwise I plan to look at the injector business end with a magnifying glass though I don't really know what I am looking for.
    I also need to decide whether to extract the other three injectors and re-seal them as the engineer saved a few pounds there too by not fitting ne seals.
    Also trying to decide how far to go in checking for swarf in the sump. I agreed with the garage to flsuh through with 10l of fresh oil. Maybe once clean at standstill and once running with a flushing additive. I really would llike to avoid removing and cleaning the sump out by hand which at the moment is the planned route to be sure nothing is in the suction strainer.
    Now have to wait two weeks as I am away until I can get the car into a garage and so have time to make up my mind.
  6. Re: Unit Injector Torques
    132 Post(s)
    1980 Post(s)
    There are no dimensions, if the area is any more that rubbed and you can feel a grove, the head is scrap. I have had to dump numerous heads because of this but thankfully they are now available aftermarket for around half the £1k of a genuine bare head.
  1. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  2. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  3. Please Help Battery + Climate Control Unit + Engine + What's next?
    Last Post: 02-05-2009, 07:39 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  5. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
