Thread: 18010. P1602. Power Supply (B+) Terminal 30 Low
Results 1 to 10 of 12
  1. 18010. P1602. Power Supply (B+) Terminal 30 Low
    Nov 2006
    Hi
    I've just connected VAG-COM to my Passat and the following error codes have popped up.
    Can anyone help,
    16727 - Camshaft Position Sensor (G40): Signal too High P0343 - 001 - Upper Limit Exceeded
    18010. P1602. Power Supply (B+) Terminal 30 Low Voltage.
    If think I can solve the first... it's the second (18010) I'd like information on. (looks expensive)
  2. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    Oct 2005
    Lutterworth
    Quote Originally Posted by Jasper View Post
    Usually means that the battery was disconnected at some time.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    Nov 2006
    Thanks Lex, that's a load of my mind.
    Is it very difficult for an average DIY mechanic to replace the Camshaft Position Sensor. Are there any special tools or equipment required.
  4. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    7 Post(s)
    The sensor might be fine.
    Any terminal 30 errors refer to the power supply to a component. I'd firstly check it is connected and that the wiring is all ok (pop the cam cover off and trace it back from the sensor)
    As for replacing it if it is dud, I'm not sure if the cam sprocket has to come off to get at it. If it does, it isn't really a diy job unless you are fairly compentent as it would basically involve doing a cambelt change with the addition of getting the sprocket on and off.
  5. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    May 2007
    knee deep in clunge
    14 Post(s)
    you need to carry out a basic setting of the tensioner via vag com an all will be ok.01 04 basic setting channel 94,make sure the engine is at normal temp then increase idle to 1200 rpm and start the basic setting check zones 2 and 3 in 3 it will go from test off to test on then ok,or final control test the n205 and feel it click when it is selected.
  6. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    Nov 2006
    Would that I could a8 tech but I only have the unregistered version "409" of Vag Com. I used this software to discover why I sometimes have a problem starting the car and why the engine warning light occasionally comes on.
    When it fails to start I turn off the ignition, wait for about a minute turn the key again it usually starts. (this is when the engine warning light sometimes appears) Once started the car runs perfectly for weeks/months before the problem occurs again.
    Is there any other way to test the sensor.
    Thanks guys
  7. Re: 18010. P1602. Power Supply (B+) Terminal 30 Low
    May 2007
    knee deep in clunge
    14 Post(s)
    do the fault codes erase
    vag diagnostics, retrofits and general repairs
  1. V5 Weird! Electrical supply problem?????
    By JohnHuson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-06-2007, 08:53 PM
  2. 07 avant 12v supply ?
    By s20a4avant in forum Audi A4 - Archive Topics
    Last Post: 14-03-2007, 06:06 PM
  3. Audi Avant - blue smoke is it terminal?
    By audy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-02-2007, 09:39 PM
  4. Passat - mobile phone power supply
    By mbertouche in forum Passat - Archive Topics
    Last Post: 21-11-2006, 04:13 PM
  5. AIR SUPPLY TO INTER COOLER
    By GRAHAM.C in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-10-2006, 05:32 PM
