Thread: Puff of white smoke on starting
Results 1 to 10 of 10
  1. Puff of white smoke on starting
    Jul 2007
    Hi Chaps,
    I have just bought an Audi A4 Avant, 1.9Tdi Sport 02Reg, engine code AWX with 118000 miles on the clock.
    When I start the engine after a couple of seconds I see a puff of white smoke come out of the exhaust. Could this be a heater plug off, causing unburnt diesel.
    Thanks for any feedback.
  2. Re: Puff of white smoke on starting
    May 2007
    knee deep in clunge
    14 Post(s)
    there is a puff who lives over the road from me and i see him every morning when i start my car,wife says he is into blonds so i am ok.lol hahahahahahahahah
    no fault keep a check on the coolant and check for fault codes
  3. Re: Puff of white smoke on starting
    Nov 2008
    N/A
    My MkIV Golf diesel did this and it was either the coolant temperature sender or the glow plugs (I changed both and it went away).
    Just an idea. It will probably show a fault in vag-com if it's the coolant sender.
  4. Re: Puff of white smoke on starting
    Dec 2006
    Quote Originally Posted by mickyboy22 View Post
    Hi Chaps,
    How many miles are you doing each day?
    Condensation?
    Check the coolant and then the oil for trace of a "cream" build up. - if cream build in oil or around cap.. head gasket.
    Rick
  5. Re: Puff of white smoke on starting
    Jul 2007
    I am doing about 34 miles a day, but have done some longer runs recently of about 90 miles. It is definately smoke I see for a couple of seconds rather than steam. Will check the water and oil later and let you know.
  6. Re: Puff of white smoke on starting
    Jul 2007
    Checked the oil filler cap and it's clean, no mayonaise, dipstick shows no sign of water and the water level is ok as well.
    Still think it is a glowplug or two off.
  7. Re: Puff of white smoke on starting
    May 2008
    any luck with this? I get a very similar problem on my AWX. replaced all plugs and checked all power is good through the harness. Still no idea why....
  8. Re: Puff of white smoke on starting
    Nov 2008
    N/A
    Quote Originally Posted by richard_gomm View Post
    Done the coolant temp sensor?
    Or plugged it in to VCDS?
  9. Re: Puff of white smoke on starting
    May 2008
    Quote Originally Posted by benjie View Post
    got a post running
    https://www.vwaudiforum.co.uk/forum/s...116#post378116
    but yes changed coolant sensor and i have vagcom
    cheers
  10. Re: Puff of white smoke on starting
    Jul 2007
    Hi Chaps,
    I have not found any cause to my smoke on starting problem, but, (not wanting to jinx things), the problem appears to have cleared up somehow.
  1. White smoke on cold starting
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2013, 10:57 AM
  2. Audi TT 180 Quatro Roadster White Smoke
    By binkybmf in forum TT - 8N Forum - 1998 - 2006
    Last Post: 31-03-2009, 12:55 PM
  3. t4 white smoke problem
    By arran alexander in forum The Commercial Range
    Last Post: 31-01-2008, 09:21 PM
  4. 2007 A4 TDi - Black Smoke
    By lukewells in forum Audi A4 - Archive Topics
    Last Post: 07-10-2007, 01:06 PM
  5. White Smoke
    By Speedy in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2007, 11:44 PM
