Thread: Brake Fault! plz help!
  1. Question Brake Fault! plz help!
    hi all, been doing a few jobs on the beast today 2000 passat tdi AJM
    Recently having an annoying problem, of which i have had a quick look into but no joy as yet,
    put right hand lock on, and CHECK BRAKE PADS warning came, on, i have newish pads (12months) and have loads of beef still on, i have connected the wear indicator wires together (temporary) but the problem still exists, i have also shorted the brake fluid sensor plug, which buzzes check brake fluid, has anyone came across this issue and maybe be in a position to give me a few pointers?
    cheers guys
  2. Re: Brake Fault! plz help!
    Jan 2009
    towcester northants
    possibily the looms from sensors to car that dissappear under wing undertray ive changed a few
  3. Re: Brake Fault! plz help!
    Nov 2005
    hi,
    sory to jack the thread...what looms are you talking about? as i think i have the same problem...are they easy to fix n cheap to fix?
    subly
  4. Re: Brake Fault! plz help!
    i had a autoelectrician have a butchers because i had another fault with the car where the heater was blowing fuses, the loom had rubbed through the otherside of the wheel arch shorting the brake pad wear line, if you wanted to investigate i would remove the wheel arch liners then just follow the wires.
  5. Re: Brake Fault! plz help!
    Nov 2005
    thank you..
    will have a look on me next day off....
    n keep it posted ...
  6. Re: Brake Fault! plz help!
    good luck mate!
  1. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  2. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
