Thread: 1996 golf cabriolet hood fault
  1. Question 1996 golf cabriolet hood fault
    Mar 2007
    Power hood does not work when switch pressed. Fluid levels in pump ok, I can operate it manually and have checked hydraulic lock in correct position, pump spins up (so it's not an electical fault) but hood doesn't move whether its up or down !
    Is there a bleed point?, is the pump serviceable? Do I need to prime pump?
    Any help would be gratefully received.
    Nov 2006
    i have the same problem only my golf is a 99...where is this fluid pump that you talk about
  3. Pump location
    Mar 2007
    Its in the boot on left hand side behind a cover that you have to unscrew. Only 4 screws,
    Nov 2006
    cheers mate, i'll have a look at that today
    Apr 2007
    hi all - i too have the same problem on a newly aquired convertible. When i press the switch to lower roof - nothing happens and i can hear no noises of pump trying to work etc. So i assume i need to replace the pump - how much would one cost roughly and how easy are they to fit? Also can the exisiting pump be reconditioned? finally is there anything i can check to establish any other causes eg. fuse or elctriucal fault etc
    many thx for any help in advance
    Apr 2007
    bump! can anyone help pls - i don't have an owners manual to locate the fuse?> have cheked the fuses under dash on drivers side but nothing labelled up for the hood. regards fraz
  1. Help neded for new Audi Cabriolet 1996 owner?
    By John Griffiths in forum 80 - 90
    Last Post: 30-05-2007, 09:21 AM
  2. Glow Plug Electrical Fault - Golf MKIII 1996 TD
    By Mikejhan in forum Golf MK3 - 1993 - 1999
    Last Post: 13-05-2007, 09:57 AM
  3. Help neded for new Audi Cabriolet 1996 owner?
    By John Griffiths in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2007, 08:26 PM
  4. Cutting out problems with 1996 Golf 2.0 Cabriolet
    By John Brogan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 05:05 PM
  5. 1996 Mk3 Golf GTI 16v - Itermittent Fault
    By Willsjunk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-07-2006, 09:49 PM
