Thread: Catalytic Convertor
  1. Catalytic Convertor
    Duffers Guest
    I have a 2003 Golf GTI (2.0L 115bhp) which has an illuminated engine managment light.
    An independent VW specialist has examined the car today and advised that it is most probably the cat convertor which requires replacement. He has cleared the fault and asked me to run the car to see if the light re-appears! He has confirmed that the original CAT is fitted to the car
    The replacement CAT is £542. Ouch! I was always led to believe these CATS indesctructable and very rarely broke. The car has only done 69k.
    Has anyone else had a problem with the cat convertor on this model? Could it be anything else?
    Any advice would be gratefully received.
    Sean
  2. Re: Catalytic Convertor
    ggordster Guest
    have the same thing with my 1.8 gti only 81k needs a new cat have priced one up from a company called motex for £211 for the part so just need to get it fitted.
  3. Re: Catalytic Convertor
    Duffers Guest
    Mate,
    That appears an incredibly low price! I would steer well clear.
    The OEM CAT's are very inferior and will almost definetly break in record time.
    I am told that VW will supply the new cat at a slightly discounted price as long as you give them the original back from the vehicle.
    I would be cautious with this company you have found.
    Good luck.
    Sean
  1. Polo Catalytic Convertor
    By WesleyP in forum Polo - Derby - Lupo - Fox
    Last Post: 19-04-2009, 05:40 PM
  2. Catalytic Convertor Guard
    By rossko1 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-04-2008, 07:26 PM
  3. VW Bora - new catalytic converter fitted...noise?
    By andycraze in forum Bora - 1998 - 2005
    Last Post: 17-12-2007, 10:05 PM
  4. Catalytic convertor
    By lynnavi in forum Fabia
    Last Post: 03-06-2007, 11:30 AM
  5. About the Catalytic Converters of Passat 2001
    By wolfterran in forum Passat - Archive Topics
    Last Post: 14-10-2006, 01:55 PM
