Thread: Engine Management Light and Limp Home Mode
  1. Question Engine Management Light and Limp Home Mode
    May 2007
    Hi there: I have a problem with my 04 TDI new beetle going into limp home mode. This has happended previously and was found to be a split pipe on the turbo. This time (2 years later) a different hose on the turbo was found to be disconnected and worn. This was replaced and re-attached.
    The car still however occasionally goes into limp home mode when I am cruising at approx 80 mpg at just below 3000 rpm and not when accelerating. The engine check light has also come back on. The system re-sets when the ignition is turned off and on again although the light stays on. The garage suggested that the turbo needed to "re-set itself" but that doesn't sound very convincing.
    Before I take it back or to another garage I would be very grateful for any indications. Cheers
    Great site!
  2. Re: Engine Management Light and Limp Home Mode
    Southern County Softy
    20 Post(s)
    Get a fault code read first.
    Have a look in the vagcom section for a member near to you.
    A4 2.5 tdi QS (mapped)
  3. Re: Engine Management Light and Limp Home Mode
    May 2007
    Thanks Kite. Will do. The garage said it was over-boosting but they didn't give me the exact code. I will get it re-read.
  1. Blue Oil Smoke - Just serviced. What's Going On?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2009, 08:47 PM
  2. HELP! Still got 'limp' mode (losing power) after paying £200!!!
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 08-04-2009, 10:28 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. passat epc warning light and limp mode
    By thebear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 11:51 PM
  5. Engine Management Light
    By Chris Russell in forum Audi A3 - Archive Topics
    Last Post: 07-10-2007, 02:59 AM
