Thread: Steering/Suspension Problem??
  1. Steering/Suspension Problem??
    Mar 2008
    Hi there, thanks (from a newbie) for help in advance. I have a 2.0 1995 audi cabriolet. Not long bought it and noticed it had a clicking coming from the drivers side when turning. I changed the outr CV joint which seemed to cure that. The passenger side seems to have a clunk to it, not all the time, sometimes when turning and sometimes when accelerating. There also seems to be a noise coming from the gearbox or shafts when pulling off, like a delay then a clunk, it jerks the gearstick a little too. There also seems like if your cornering and you go over a slight pothole or bump the steering jerks and shakes more than normal, sometimes almost pulling the wheel out of my grip. I know there is a lot there but didnt know if it was all related or if there are lots of differnt components that are failing. I know the rubber has gone on the passenger bottom ball joint which I intend to change anyway and when i jacked the passenger side front up and turned the driveshaft by hand there seemed to be a bit of a clunky rattly sorta noise. when it just starts to turn, the harder i turned it, the louder the noise. Any help, much appreciated.
  2. Re: Steering/Suspension Problem??
    Dec 2007
    8 Post(s)
    Quote Originally Posted by barneysvw View Post
    Sounds like you should change the lower ball joint lhs and probably as soon as possible in case it comes adrift .you need to mark position of old unit before removal so you can fit new unit in same position as there are slots for movementof ball joint
  1. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  2. Power problem turbo not working
    By marfitzd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 11:04 AM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
