Thread: vw passat will not tick-over
  1. Cool Please Help!!- VW Passat Will Not Tick-Over
    Jan 2009
    Hi, can anybody help?
    I have a Passat 1.8 SE 20v, model year 2000, it broke down recently and would not turn over, when i turned the key it would just start 2 relays under the dash chattering away so i thought one if not both possibly faulty, they were numbered 372 & 377, i got some info off this forum & replaced 372 which was the fuel pump relay but it still wouldn't start & relays still chattered.
    I was able to get it started with a jump start so i removed the battery & charged it, when i put it back on still had same problem so fitted new battery, car now starts but will not tick-over, it just cuts out as soon as you take foot off throttle, i am totally stumped as it was fine before battery went flat.
    Any ideas will be much appreciated.
    Regards
    Steve.
  2. Re: vw passat will not tick-over
    Dec 2007
    I am almost certain you need to do a throttle body adaptation.Drivers door open,switch on ignition,leave for about a minute,turn off and then start the engine to check.Hope this helps
  3. Re: vw passat will not tick-over
    Jan 2009
    Quote Originally Posted by Passata View Post
    Hi Passata,
    thanks for your reply, i tried what you suggested a couple of times but no go, thanks again.
    Steve.
  1. Passat Fuel Pump Problems
    By steve Mac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-08-2010, 06:45 AM
  2. 1997 Passat - which VW alloys will fit?
    By g111mds in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 01:53 PM
  3. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2007, 07:33 PM
  4. Passat issues
    By Notwork Ste in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-07-2007, 01:26 PM
  5. Passat service tick list
    By ImolaOrange in forum Archive posts
    Last Post: 08-01-2007, 12:23 PM
