Thread: drivers side door dropping???
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. drivers side door dropping???
    hi, my door kept getting stiff to open and today i looked and saw my door has dropped about 1cm and is rubbing on the pillar when opening and closing, is this an easy fix. thanks alot steven
  2. Re: drivers side door dropping???
    Jan 2009
    leicester
    what we used to do is put a 17 or 19 mm socket in the bottom hinge and then sut the door slowly until the socket stops it the push the door shut but not to much, this will lift the door up and problem fixed.
  3. Re: drivers side door dropping???
    what do you mean put it on the hinge and close the door to force it out a little??? is there no adjustment on the door? thanks
  4. Re: drivers side door dropping???
    chrismaher2007 Guest
    i have exactly the same problem so im interested in a fix myself.
    i would have thought something has just loosened and needs to be tightened
  5. Re: drivers side door dropping???
    yeah and i dont realy want to put a socket in my door and force it shut to fix it, there must be a way to raise it, theres nothing in the haynes manuel i may have to call audi
  6. Re: drivers side door dropping???
    Jan 2009
    leicester
    the doors drop when they are swung open all the way. there is adjustment on the catch on the pillars. the socket trick does work, only needs to be put in the hindge and close the door un till the socket stops it then push the door closed a bit more.
  7. Re: drivers side door dropping???
    had a similar problem only my door was rubbing on the sill. Found I had a bit of play in the bottom hinge (only noticeable when the door was nearly closed).Ended up putting a new hinge on - job done.
  8. Re: drivers side door dropping???
    ok so you just fitted a new hinge to the door. is it easy to do because i have that problem as it is only noticable when the door is almost closed so it must be the same problem as wot u had. thanks
  9. Re: drivers side door dropping???
    sorry for not getting back to you, been away for a couple of weeks. Yep it was fairly easly, removed the door trim and the bit of plastic in the drivers footwell - bolt hidden behind it, disconnect the wiring that passes into the door (speakers, elec windows etc.) support the door and undo a couple or three bolts.
    Did it on my own (with a bit of moaning and swearing) and it took me about 3/4 of an hour. Probably a lot quicker if you've got someone to hold the door - If you have to do it on your own, I found a trolley jack quite usefull to support the door
  10. Re: drivers side door dropping???
    Jul 2009
    Falkirk, Scotland
    My S4 drivers door dropped slightly and my mate who is sh*t hot with cars said it is a common problem. He opened my door fully open and we grapped the door and lifted it up. Seemed to help quite a bit, worth a try.
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  3. problem with height of car
    By vw754 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-05-2009, 02:14 PM
  4. Audi S6 "daylights"
    By ryang80085 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-07-2008, 11:01 PM
  5. Drivers Side Electric Window not working
    By philpg00 in forum Touran - Sharan - Caravelle
    Last Post: 24-04-2007, 01:37 PM
