Thread: Water Pump - Plastic Impellor
Results 1 to 8 of 8
  1. Water Pump - Plastic Impellor
    Jul 2007
    Rochdale UK
    I was going to change the water pump when I change the timing belt this weekend. I have read about pottential failures of the plastic impellor but I can't find a genuine metal impellar pump.
    VW only list the plastic impellor metal impellor is now obsolete.
    GSF are getting plastic impellor pumps in tomorow and have, metal impellors on back order with no expected delivery date.
    Euro car parts list a metal impellor pump.
    I would have liked a Genuine water pump is the metal impellor better than a genuine VW pump.
    Anybody got any other ideas where else I could look.
    Cheers Ben.
  2. Re: Water Pump - Plastic Impellor
    Jul 2008
    I just replace mine each time i do a cambelt with what ever is in the box - usually the vag plastic type. It's not at all likely to fail in the 60'000 interval. I have never removed one at 60'000 that looked ready to fail.
    I think the problems occur when they are not changed at each cambelt service TBH, although I done one on a mates TDI the otherday @ 178'000 which had the original in. There was play in the shaft but it was all intact.
  3. Re: Water Pump - Plastic Impellor
    Norfolk
    It doesn't matter what the impeller is made of. The problem was that it came loose on the shaft so didn't turn. This was a manufacturing fault that can happen whether it is made of plastic or metal.
  4. Re: Water Pump - Plastic Impellor
    Jun 2006
    UK, Mids
    This didn't just affect VAG cars, it was a late 1990s, early 2000s problem as far as I can see where a sort of fibre reinforced plastic was used that seemed to be affected by the coolant over time and become weak. It would usually shear at the weakest part near the shaft, as so the impeller would not spin and would just jump around with bits chipping off. I don't see any reason why they shouldn't make them out of plastic as long as it is at least adequate for the job. If I bought a new VW pump and it was plastic I would be ok with that, as the manufacturers who make the pumps must have got a besmirching by the car makers and will have undoubtedly done a few more years' worth of material (and coolant formulation) research.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Water Pump - Plastic Impellor
    Aug 2007
    i had a polo impller fail at 18k miles and light use so mleage is no guide. It was probably faulty from thefactory but VW would not pay towards it at all
  6. Re: Water Pump - Plastic Impellor
    Pembrokeshire
    22 Post(s)
    just out of interest, how old was the polo when the pump failed?
  7. Re: Water Pump - Plastic Impellor
    Aug 2007
    less than 4 years - I tried to get a goodwill payment from VW even though the warranty had expired
    2000MY
  8. Re: Water Pump - Plastic Impellor
    ChillOut Guest
    Quote Originally Posted by passing View Post
    2000MY
    Good Will and VW go together like peaches and concrete. Easier getting a free drink out of a Vogon. £400 for a service, £200 at an independent, you think they would like to keep your custom.
  1. How to change water pump belt
    By mm707 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-07-2009, 06:22 PM
  2. ADR engine - Power steering / water pump belt
    By ANDY-C in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 01:11 PM
  3. Failed Water Pump??
    By Degsy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-04-2009, 05:34 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Polo Cooling system
    By nigell in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 09:35 PM
