Thread: Power window switch failure
  1. Power window switch failure
    Aug 2007
    This morning I went to use the DS window switch to raise the window automatically and it didn't work. It still works when lowering the window. Window also still works when using the switch manually. Can anybody tell me if the switch is the problem or is the logic controlled elsewhere? e.g. relay.
    If it is the switch does anybody know how much a replacement would cost?
    The PS window still works fine.
  2. Re: Power window switch failure
    Southern County Softy
    20 Post(s)
    Roll the window up hold the switch up for 2 secs.
    Roll the window down hold switch down for 2 secs.
    That should reset the auto function.
    A4 2.5 tdi QS (mapped)
  3. Re: Power window switch failure
    Aug 2007
    Sorted. Thanks.
  1. Power window problem
    By erico in forum Early Passat Forum - Pre 97
    Last Post: 19-04-2008, 09:25 AM
  2. Replies: 0
    Last Post: 02-04-2008, 02:14 PM
  3. Power window problem- update
    By kjellz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-03-2008, 02:34 PM
  4. How does the Quattro system work?
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
