Thread: Fly by wire over-rev between gears
Results 1 to 10 of 18
  1. Fly by wire over-rev between gears
    Apr 2009
    Chessington
    Hi I have just moved on from having a mk2 16v and now have an a3 quattro sport.
    I have noticed that it over revs between gear changes and have been told this is due to the fly by wire throttle control. Does anyone know of a solution to this problem, I would much appreciate advise. thanks
  2. Re: Fly by wire over-rev between gears
    Cheshire
    Hi Mate,
    Suffering the same issue with mine. Has been diagnosed by several to the clutch pedal switch...seems to fit being that I had a new clutch pedal and cylinder replaced by a non specialist and the clutch pedal switch ain't there anymore.....have been away at sea since then so I haven't had chance to get it sorted, and either prove/disprove the theory.
    I am hoping that this is the issue anyway....quite sure there may be other answers though.
    Good luck!
    1999 Audi S3 now revo'd
  3. Re: Fly by wire over-rev between gears
    Apr 2009
    Chessington
    Oh ok that sounds posible, suppose it gets the revs down quicker when it knows the clutch has been ingaged. I just thought thats how the car was ment to be
    Cheers for the info mate, i'll look into it. (let me know if thats the problem on yours)
  4. Re: Fly by wire over-rev between gears
    135 Post(s)
    2026 Post(s)
    The clutch pedal switch tells the ECU you have pressed the clutch so the revs drop faster, it is a common failure and can be checked in Measuring Blocks 08 if you have access to diagnostic equipment.
  5. Re: Fly by wire over-rev between gears
    Cheshire
    Nice one Crasher!
    Will be checking it this weekend hopefully and will report back! Fingers crossed!
  6. Re: Fly by wire over-rev between gears
    Apr 2009
    Chessington
    yea thanks crasher, will have to take it to my mate at kwick fit and whack it on the machine
  7. Re: Fly by wire over-rev between gears
    Apr 2009
    Chessington
    yep put the car on the tester and sure enough it came up with the p1539 clutch switch improbable error. got the switch coming, probably sort it monday. thanks again.
  8. Re: Fly by wire over-rev between gears
    Cheshire
    Nice one! Didn't manage to get home to do mine this weekend...hopefully will be the same thing on mine!
  9. Re: Fly by wire over-rev between gears
    Cheshire
    Right then, I have been hooked up to VAG-COM at Votex, no fault codes were stored, but I still have the over-rev, and still can't see a switch where the drawing says it should be! Were all S3s fitted with a switch? Would bypassing the switch in some way prevent a fault code being registered?
    Any thoughts gratefully recieved!
  10. Re: Fly by wire over-rev between gears
    135 Post(s)
    2026 Post(s)
    The switch is on the bracket above the pedal, if you can’t see it that may be the problem!
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  3. Replies: 6
    Last Post: 17-08-2008, 06:11 PM
  4. rev counter wire up
    By simon82 in forum Chat - Anything with wheels
    Last Post: 11-12-2007, 12:57 PM
  5. need to connect front FOGS to mk3 gti
    By cyrilp in forum Golf MK3 - 1993 - 1999
    Last Post: 25-11-2007, 11:17 PM
