Thread: Rear wiper not parking properly.
  1. Rear wiper not parking properly.
    Ayrshire
    2003 Golf TDi Match.....
    When I use the back wiper, annoyingly it does not stop where it should in the horizontal position just above the lower edge of the window.
    It always travels a few inches back up the window before stopping!
    Everything else works fine, and it is just cosmetic, but as I said slightly annoying.
    No point in taking the arm off the spline shaft and re-positioning it, or it is going to go down onto the paintwork on the downward stroke!
    Any ideas what the problem is??
    Al.
  2. Re: Rear wiper not parking properly.
    I would have said pop the arm off the splines and reposition it.
    Failing that id be replacing the motor.
  3. Re: Rear wiper not parking properly.
    Near Blackpool
    48 Post(s)
    Check that the copper pipe that goes threw the motor isnt broken and therefor water leaking into the motor. A common fault with them as the greese dries out and the pipe twists. This then causes electrical faults like as you have mentioned. The motor records the position of the wiper. If it is getting damp it could be confused on where the "park" position is. I had a problem with the water jet not staying straight. I baught a kit from VW/Audi and it came with all new cogs and pipes. It works a treat now. Hope this helps
  4. Re: Rear wiper not parking properly.
    Bath, Somerset
    Quote Originally Posted by jonathanfenton View Post
    As above, new motor required!!
    Scott
    Golf GTi 180bhp 6 Speed, Tornado Red, Electric Sunroof, Winter Pack, Climatronic, Black Leather, Santa Monica Alloys, Centre Arm Rest, 6 Disc Changer, R-Tech Remap...
  5. Re: Rear wiper not parking properly.
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by dubcruiser View Post
    Lol well you could try drying out the contacts after you have stripped it down...... or you could buy a scrappy motor for £30BUT then you have the problem that occurs when the wiper isnt used for a while like on scrap motors where the copper pipe twists and brakes........ So i would suggest £70-£90 for a new motor....
  1. rear wiper wont switch off
    By Almac1903 in forum Passat - Archive Topics
    Last Post: 25-01-2008, 09:10 PM
  2. How does the Quattro system work?
  3. Replies: 3
    Last Post: 01-03-2007, 08:47 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
