Thread: Help With cruise please
  1. Help With cruise please
    Apr 2009
    cb99en
    I have a 2006 estate S model, and want the cruise control fitted, I have read some of the topics on here about it but I am a bit confused.
    Some of you are talking about a 2nd stalk for cruise which needs a new lower cowl, and some about a combined indicator/cruise stalk? which is the case or is there an option.
    I have also seen it mentioned that an extra wire may need to be run into the ECU? is this the case? I was under the impression that I could remove my indicator stalk and fit a combined one, then just get the ECU programmed with VAGCOM or similar?
    Help Please
    Many Thanks
  2. Re: Help With cruise please
    On the B6 it's a separate stalk. Lots of info on www.tyresmoke.net. PM Shark_90 if you're in the Midlands and want it retrofitting - he knows his stuff.
  3. Re: Help With cruise please
    May 2008
    The Passat uses another stalk, which is fitted just below the usual left hand indicator stalk. Some VW's, like the Golf, have it on top of the indicator stalk.
    Follow the link below for further deatails.
    http://www.vwcruise.com/
  4. Re: Help With cruise please
    Rutland
    You get a second stalk, below the indicator/lights stalk and a new lower cowl is needed. I think the confusion arises because you get a replacement indicator /lights stalk as well. This is because the old indicator/lights stalk and the switching unit it is attached to are thrown away and replaced by a new combined unit with two stalks and switching for indicators, lights and cruise.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  5. Re: Help With cruise please
    Sep 2007
    South Manchester
    See my post here.
    https://www.vwaudiforum.co.uk/forum/s...light=vwcruise
    I think in the current climate the dealers will probably do it for a good price, I've read somewhere on here that it's been done for Ł150.
    I have been very pleased with mine & wouldn't be without it.
    VWCruise did a good job without messing around at the dealers
    The ECU has to be opened and new wire attached & fed through to the new stalk, like me, your wiper lever will need to be taken from the old stalk unit (Rear wash) & fitted to the new unit as part is for saloon.
    Ps tried to flog the old unit & cowl on ebay but no takers, guess it will be in demand in a few years.
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  6. Re: Help With cruise please
    Mar 2009
    Sleaford, Lincs, UK
    Skoda garage quoted me Ł70 parts and 1 hour 30mins labour charge. That was when I was looking to buy a Sport from them
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Question Cruise control turning off on its own
    By Jettadame in forum Jetta MK3 - 2005 - 2013
    Last Post: 06-05-2009, 10:34 PM
  4. Touran 2.0 TDI: cruise switch/contact problem
    By kokeilut in forum Touran - Sharan - Caravelle
    Last Post: 11-04-2009, 10:46 AM
  5. Coding of engine : witout cruise control
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2009, 08:19 PM
