Thread: A4 2.5 tdi CVT problem
  1. A4 2.5 tdi CVT problem
    Apr 2009
    belfast
    Have a customers Audi A4 2.5 tdi CVT giving trouble as follows:
    1) when car is running to operating temperature the temperature dial suddenly drops downwards
    2) the traction control light comes on
    3) shudder comes into car (CVT gearbox problem??)
    4) after the above happens if coming to a standstill in car its as if the brakes are stuck on.
    We are aware of the problems with the CVT box but this seams just a little different.No faults showing up and the indicator on the dash for which gear you are in is acting normally.
    Please can anyone shed a little light on this matter
  2. Re: A4 2.5 tdi CVT problem
    Did you get anywhere with this issue? My car has similar symptoms and looks like the throttle valve actuator, was wondering if you concluded the same?
  1. Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    By pltoff1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2008, 11:17 AM
  2. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
