Thread: electrical fault ibiza
  1. electrical fault ibiza
    a mate has a 2004 ibiza 1.2 with a strange electrical problem. the central locking is intermitant,but the main problem is when you start the car it fires up and runs normal until you press the brake pedal. then the dash lights start flickering on and off and if you switch the indicaters on with the pedal pressed the the indicaters start blinking real fast as if there is a bulb blown, but the second the pedal is released everything returns to normal. a real headmelter. i put a fault code reader on it and 2 codes came up,17925 main relay [j271] electrical malfuntion p1517. and 01336 data bus for comfort system static faulty. i cleared both codes but the data bus one keeps coming back everytime. anyone have any ideas? thank you.
  2. Re: electrical fault ibiza
    Nov 2008
    folkestone.kent
    if you have access to vcds look in the can gateway it will do a scan of the can networks and tell you if there is a communication problem,if you have an oscilloscope you can check the signals on a two channell system to pin point a communication fault
  3. Re: electrical fault ibiza
    Quote Originally Posted by VAGMAN54 View Post
    no mate i wouldn't have access to anything that fancy. do u know what the comfort system does? and where the hell it is located? that wud be a great help. thanks.
  4. Re: electrical fault ibiza
    Nov 2008
    folkestone.kent
    in basic terms it does the central locking,interior light control,alarm,interior monitoring,i dont know where it is on seat models ..sorry..have you looked on vcds locations the chances are there will be somebody close to you who can look at it for you.if your near canterbury in kent i will do it for you
  5. Re: electrical fault ibiza
    cheers mate but i live in ireland.
  6. Re: electrical fault ibiza
    Nov 2008
    folkestone.kent
    ha ha ....sorry mate i dont travel that far but good luck
  1. Seat releases first details of new leon cupra and ibiza fr
    Last Post: 19-04-2009, 07:53 PM
  2. Replies: 0
    Last Post: 18-04-2009, 09:57 PM
  3. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  4. TT dashboard electrical fault
    By umesh in forum TT - 8N Forum - 1998 - 2006
    Last Post: 25-02-2007, 11:04 AM
  5. Audi A6 2.5 TDi Auto electrical fault
    By afe410 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-11-2006, 11:24 AM
