Thread: ESP off light etc
Results 1 to 10 of 18
  1. Question ESP off light etc
    West Sussex
    My other half owns a 2005 Polo 1.9tdi 130. Recenetly the 'ESP off' light together with the icon showing the 'skidding car' has started to light-up intermitantly. Sometimes it only stays on for a few minutes & other times stays on longer.
    The car has been plugged-into a VW computer which has shown the following: ECM has no load signal from the alternator, possible wiring fault or faulty alternator. The alternator has been checked for under/over charging, but all is okay.
    Can anyone please help with suggestions for resolving this problem??
    Also what has the alternator to do with the ESP system/light??
    Many thanks.
    Chas.
  2. Re: ESP off light etc
    134 Post(s)
    2005 Post(s)
    That fault code was stored on the ABS system?
  3. Re: ESP off light etc
    West Sussex
    I think I can now be more specific reagrding the results from the VW computer. This is what it said:
    Diesal - Direct Fuel Injection / Glow Plug System w/pump - i
    1 Fault / notes detected
    17911 P1503 035
    Load signal from generator terminal DF.
    ABS/EDL/ASR/ESP - Bosch 8.0
    18265 000
    Load signal - fault signal from engine control module.
    Hope this helps????
  4. Re: ESP off light etc
    134 Post(s)
    2005 Post(s)
    What is the engine code (ASZ, BLT?) and is the chassis number before wvwzzz9Nz5Y180000 or after wvwzzz9Nz5Y500001?
  5. Re: ESP off light etc
    West Sussex
    The engine code is: BLT
    The chassis no: wvwzzz9Nz6Y103884.
    Thank you very much for your help with this.
  6. Re: ESP off light etc
    134 Post(s)
    2005 Post(s)
    It is a 2006 model but registered 29/09/2005.
    Both codes point to a faulty alternator IF the wiring is OK. A fault code read of the central electrics unit should also be carried out to see if there is a code there as the blue L wire from the alternator goes into this unit and I would check the 2 pin wiring connector on the starter motor top clip where a blue and a brown/red wire have connections and make sure these are clean and not snapped, paying special attention to the brown/red wire which is the DFM signal to the engine ECU.
  7. Re: ESP off light etc
    West Sussex
    Thanks for that info Crasher. I will get those points checked out & let you know how I get on.
    Presumably if all of the other checks you have mentioned are ok, then it is a faulty alternator that is turnig off the ESP system?
  8. Re: ESP off light etc
    134 Post(s)
    2005 Post(s)
    Yes, I have seen it before.
  9. Angry Re: ESP off light etc
    West Sussex
    I have had a new alternator fitted and the esp off light is still coming on. Please help
  10. Re: ESP off light etc
    Nov 2008
    folkestone.kent
    umh now lets see .................did you check what crasher told you to check before the alt was changed ??
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. epc light , esp light , low power , high revs ..help...
    By b2online in forum Audi A3 - Archive Topics
    Last Post: 06-05-2008, 11:32 PM
  4. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  5. Lupo GTI 2004 ESP Light ON
    By jostiband in forum Polo - Derby - Lupo - Fox
    Last Post: 10-01-2007, 01:16 AM
