Thread: Code 17965
  1. Code 17965
    ChillOut Guest
    17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent.
    What might this refer to?
    The car has been smoking and will run into overboost limp if pused hard, but gives this reading even with easy normal driving.
    Using Gendan with 409.1 software - I hope this is the correct forum.
  2. Re: Code 17965
    Oct 2007
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    Retrieved from "http://wiki.ross-tech.com/index.php/17965/P1557/005463"
  1. Error Code 17965
    By Sharky_82 in forum VCDS - General Questions
    Last Post: 29-07-2011, 12:22 PM
  2. Intermitant Boost Fault (Code 17965)
    By dazrick68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2009, 08:51 PM
  3. test key code?
    By perfection in forum Audi A3 - Archive Topics
    Last Post: 16-04-2008, 12:12 PM
  4. error code 17965 on 110 tdi, need a new actuator?
    By tezray in forum Archive posts
    Last Post: 26-10-2007, 04:56 PM
  5. engine trouble code 17965 - turbo dying? HELP!!
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-08-2007, 10:05 PM
