Thread: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
Results 1 to 10 of 15
  1. Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    Hi guys, got my self a pretty good nick A6 2006 SE 2.7, really nice car with loads of go, the problem is this little yellow springy thing comes on when I hit about 3000rpm, the manual says go see the ******** right away, anyway, i bought a VAG-COM from ross tech, well worth it, the light goes way when the car is off and doesnt come on until you floor it basicly, heres what ross-tech say:
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
    57 61 62 72 76
    VIN: REMOVED Mileage: 122670km/76223miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F1 910 401 P HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000CG 0030
    Revision: --H03--- Serial number:
    Coding: 0011382
    Shop #: WSC 00088 210 83343
    3 Faults Found:
    005663 - Glowplug for Cylinder 6 (Q15): Open Circuit
    P161F - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 122458 km
    Time Indication: 0
    Date: 2009.04.22
    Time: 07:14:37
    Freeze Frame:
    RPM: 882 /min
    Torque: 109.2 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 22.5 %
    Temperature: 18.0°C
    004195 - Fuel Pressure Regulation: Control Range Not Reached
    P1063 - 001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11110001
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 122474 km
    Time Indication: 0
    Date: 2009.04.22
    Time: 07:29:45
    Freeze Frame:
    RPM: 3213 /min
    Torque: 444.6 Nm
    (no units): 5.0
    Voltage: 13.98 V
    Pressure: 802.3 bar
    Duty Cycle: 54.4 %
    P1063 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 122474 km
    Time Indication: 0
    Date: 2009.04.22
    Time: 07:29:45
    Freeze Frame:
    RPM: 3213 /min
    Torque: 444.6 Nm
    (no units): 5.0
    Voltage: 13.98 V
    Pressure: 802.3 bar
    Duty Cycle: 54.4 %
    Readiness: 0 0 0 0 0
    The glo plug issue only actualy showed up when I updated the MMI system, amazing, not it woulnt be that would it? i know jack about cars and don't want to get rippped of by audi or the specialists, the specialist i saw was talking about getting a special man in to test engine presure and what not,is this right?
    Thanks guys, really suck with this issue, and too many white vans are going just as fast as me i need my vavavoom back
    Forgot to mention, the count is low because i reset all the codes the other day as some others from an issue with the door were showing up, but basicly i get this every day
  2. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    Can anyone help, really stuck with this one, i have a feeling its either the mass airflow filter or the fuel lift pump.
  3. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    8 Post(s)
    Is your warranty up then? If not i'd just get it to audi and let them look.
    Though your fuel pressure is low, shouldn't it be 1600 not 800 bar?
  4. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    its a 06 SE so i don't know, whats the warrenty, it second hand, bought it 2 weeks ago, how long is the audi warrenty, 1 year? or is it longer for the engine or something?
  5. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Southern County Softy
    20 Post(s)
    3 years warrenty on the car, get to a dealer
    A4 2.5 tdi QS (mapped)
  6. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    wicked, i'll pop down at the weekend, thanks mate, any insight into the error codes, the specialist is saying gloplug and i know that wont make a bit of difference since its not even cold
  7. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    20 Post(s)
    If you still have warranty, just get the dealer to sort the problems..
  8. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    8 Post(s)
    Glowplugs are what help a cold diesel engine start, they cause a hotspot to help combustion until the engine is warm enough, only cost a few quid each and fairly simple to fit.
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  9. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    just checked, not in warenty, 75,000 miles not 60,000 and missing two service stamps, god damit !!! any other ideas as to what this could be, the pipes around the engine are fine with no cracks.
  10. Re: Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    Apr 2009
    Birmingham
    i thoguht this about the gloplugs, specialist is saying 2 hours to fit one gloplug... i'd do it my self but i need toi know the tools and instructions.
  1. Audi set for 12th record-breaking year in a row
    Last Post: 31-07-2007, 08:34 PM
  2. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  3. AUDI UK ENDS 2005 ON ITS BEST HIGH TO DATE
    Last Post: 23-12-2005, 09:27 PM
  4. New A6 to dominate Audi stand
    Last Post: 23-06-2004, 11:19 PM
  5. History of Audi
    By stuart in forum History - Audi
    Last Post: 08-05-2004, 09:05 PM
