Thread: Code 16497 on Passat B5 1.8T
  1. Code 16497 on Passat B5 1.8T
    Kettering, Northants
    I've got a code 16497 (P0113) Intermittent, from a shareware VAGCOM version which I believe is to do with a Low Temp of some sort. Engine is running giving variable unprdictable flat spots. The car is a 2000 B5 Passat 1.8T Sport.
    Anyone havefurther info on this fault? Anyone local to Kettering (NN15) with full VAGCOM who could help investgate
  2. Re: Code 16497 on Passat B5 1.8T
    Oct 2005
    Two very comprehensive writeups here;
    http://www.bba-reman.com/content.asp...NEXT_DTC_P0113
    http://www.obd-codes.com/p0113
    Both procedures, I think, can be done with the shareware version
  3. Re: Code 16497 on Passat B5 1.8T
    Sam, thanks for the info.
    Just a note, if it is a failed the Intake Air Temp, is this the hot wire sensor or is there another one to track down?
  4. Re: Code 16497 on Passat B5 1.8T
    Oct 2005
    It's the hot wire sensor, you're correct.
    The IAT is "in" the MAF
    I've edit this post so many darn times!
    My limited understanding tells me it's not the MAF, but it is a part of the MAF. Too many terms to describe the same thing.
    Replacing the MAF seems the easiest route to take but someone else may have another idea.
    <edit 3402734534>
  5. Re: Code 16497 on Passat B5 1.8T
    To clarify it is the sensor that sits in the airflow just up from the throttle body into the intake plenum on the 1.8T engine?
  6. Re: Code 16497 on Passat B5 1.8T
    Oct 2005
    Yes
    (still not 100% convinced the MAF and IAT are the same tho )
  1. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  2. passat 2.0se 2001 fault code
    By mendit in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 10:55 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. Replies: 0
    Last Post: 03-04-2007, 04:25 PM
  5. 2004 Passat 1.8T SE - Spare Key Coding Problem
    By Martin in forum Archive posts
    Last Post: 25-02-2006, 02:26 PM
