Thread: Sharan - air con fault
  1. Cool Sharan - air con fault
    Apr 2009
    South Yorkshire
    Site newbie here who owns a 53 plate Sharan 1.9tdi 115 bhp in need of some help and assistance from you all. My problem is this - non-working air con. Although our summers are hardly spectacular, with young children, this air con gadget is priceless - or it should be!! When I turn on my blower fan, it doesn't work on speeds 1 & 2, but does on 3 or 4. But air con doesn't work when dial turned to screen on any power level. When I turn the fan off, the heated screen switches on and the air con light lights up, but doesn't work! I've had it re-gassed a couple of times, no joy. Is there a simple, relatively cost free option to fix this thing? I've put up with this now for 3-years and the wife and children have had enough of it!! Any suggestions/solutions?
  2. Re: Sharan - air con fault
    High Wycombe, UK
    if you do a search on this forum its a fairly common problem:
    https://www.vwaudiforum.co.uk/forum/s...ioning+problem
    i have a similar problem on my golf at the moment
    what you do is unscrew the glovebox and remove
    get behind it and you see a green resistor, remove it, take that to VW and get a new one for £20, reinsert
    job done.
    also check you air filter coz apparently if that gets clogged it causes this green resistor to overheat and therefore causes the problem in the first place
    I'm not sure how easy it is to remove the glovebox on Sharans, but in my golf its a nightmare.
    hope it works!
  3. Thumbs up Re: Sharan - air con fault
    Apr 2009
    South Yorkshire
    now that sounds easy!! Will get it sorted over next few days, thanks
  4. Re: Sharan - air con fault
    Aug 2006
    Southampton
    If you need any more help, see my post Re: Air conditioning / blower odd problem dated 2-2-2009, where I describe the course of action plus a couple of pictures of the little green resistor.
  1. Sharan Air Con Problem
    By phall in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2011, 02:12 PM
  2. S4 Air con challenge Help please
    By Audinzs4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2009, 12:02 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Question Air Con Fault...
    By bora250cr in forum Bora - 1998 - 2005
    Last Post: 21-05-2008, 01:22 PM
  5. Air Con Condenser fault? VAGCOM detectable?
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2007, 08:38 PM
