Thread: Greetings.....and a couple of questions
  1. Greetings.....and a couple of questions
    Apr 2009
    Hi All,
    After owning 6 Audis in succession, I have just ordered a new Golf GT TSI.
    I was hugely impressed by the combination of refinement, quietness, handling and build quality, all of which are a significant improvement on my A3. The engine is an absolute gem, and only marginally slower than my current 2.0T, but considerably more economical.
    I have spec'd the car up quite well, including the RCD510 + Dynaudio sound system. Is it also worth getting the DAB upgrade, or is coverage still too patchy to bother with ?
    Also, is the Winter pack worth having ?
    Cheers,
    Chris.
  2. Re: Greetings.....and a couple of questions
    Apr 2009
    Not sure about the DAB, but personally I think heated seats are fantastic, so I would say the winter pack was well worth it just for that.
  3. Re: Greetings.....and a couple of questions
    Feb 2009
    if you get DAB you lose the MFD for your mp3 player/ipod
    I'd choose winter pack al the time, esp for the heated seats, I'd also choose at least the conv pack if not the luxury one
  4. Re: Greetings.....and a couple of questions
    Apr 2009
    Thanks for the comments.
    Good point about the iPod interface.
    I'm getting the standard alcantara seats, so didn't think there would be much benefit from heated seats (?). I am getting the convenience pack however.
  5. Re: Greetings.....and a couple of questions
    Aug 2008
    Quote Originally Posted by cs2009 View Post
    I have the RCD510 and got the DAB as a FOC upgrade from VW for having to wait so long for my car (order placed April 08 for Sept delivery, car delivered Dec) and find it's coverage in and around London near perfect, really built up areas can be a problem sometimes - The sound quality over FM is fantastic - you really notice it when it does sometimes loose DAB and switches automatically to the same station on FM.
    The other thing you lose is TIM (the clever thing that saves the last few traffic news reports) however (in London anyway - but think it is national) there is a dedicated Traffic DAB station which is as good. The other thing I did was buy the RDS-Trafic add-on for my TomTom but to be honest the DAB Traffic station is better than that.
    As for loosing the Ipod connection option, again I would not worry about that - just get yourself a 8 or 16 GB SD card and put all your music on that in mp3 format (you can get software that converts the iTunes mpa (?) format to mp3) and the whole thing is a lot cheaper and no Ipod left in the car for someone to pintch ! The one thing I would say when buying a SD card is get a black one - my blue one is rather obvious !
    Hmmm - heated seats - that will be YES imo!
  6. Re: Greetings.....and a couple of questions
    Apr 2009
    Can you confirm that an 8gb sd card works then? The manual says a max of 2gb so I haven't risked buying a bigger one yet.
  7. Re: Greetings.....and a couple of questions
    Mar 2008
    Check your manual for SD specification on your device and use this link to check for the maximum SD size compatability for your unit
    http://www.sdcard.org/developers/tech/
    hope that helps.
  8. Re: Greetings.....and a couple of questions
    Aug 2008
    Quote Originally Posted by jay89 View Post
    I can confirm I am using a 8GB SDHC card - my manual under Data Media (page 27) says :
    * The unit can read SD memory cards [snip] with capacity of up to 2 GB. The unit does not support other memory cards [snip] such as SDHC cards
    * The unit also supports SDHC memory cards [snip] with a capacity of up to 32 GB
    which is as clear as mud - but I think as long as it says the last point, i think you should be ok to ignore the paragraph above it and if it does not work go back to VW.
