Thread: Broken fuel- and temperature gauge T4 -91
  1. Broken fuel- and temperature gauge T4 -91
    Apr 2009
    Hi, I have a VW Caravelle T4 -91 with AAC-engine (2.0L gasoline).
    Since I bought this car, the fuel- and the temperature gauges has been broken. But now I decided to try to fix it.
    As far as I've heard, this is a quite usuall problem on the older VW:s, so I wonder if someone here have any hints for me?
    I've taken the dash out and disambled the "fuel and temp-frame" from the electric card. I also tried the gauges by putting cables from a 6V-battery directly on the connectors, and then both gauges move...
    So, if someone knows anything about this, please tell me.
    Sorry for my english, I am a stupid Swede...
  2. Re: Broken fuel- and temperature gauge T4 -91
    Take a look at this post from the forum t4 fuel and temp gauge not working
    The second post has what looks like a good guide to the problem.
    chris
  3. Re: Broken fuel- and temperature gauge T4 -91
    Apr 2009
    Dry joint on the back of the gauges or the voltage stableizer, just need to resolder the conections. Its hard to see sometimes but resoldering them works!
  4. Re: Broken fuel- and temperature gauge T4 -91
    Mar 2009
    I've the same prob with the temp gauge in my T4 Transporter however it does occasionally work for very short periods of time. It is obviously a break in a connection somewhere along the line and it seems as if the instructions above could be the solution however they state that they apply to pre '96 analogue models. Mine is a '99/00 and fitted with the digital instruments.
    Does anyone know if the same problem is common & if the same solution works on the later machines??
    Thanks All....
  5. Re: Broken fuel- and temperature gauge T4 -91
    Apr 2009
    Sorry dont know about the later ones but sounds like it could still be the voltage stableizer soldering, normally looks like a small black transitor type thing with 3 connectons.
  6. Re: Broken fuel- and temperature gauge T4 -91
    Mar 2009
    Nice One Scrotum Head, it does sound similar though. I'll have a look at over the next week in the hope it is.
  7. Re: Broken fuel- and temperature gauge T4 -91
    Gloucesterhire
    I`ve fixed 2 t4`s with the same problem,go here for the complete fix.
    http://www.vwoc.euromarques.com/tech.../t4_gauges.htm
    J
    T5 LWB 2007 102 Transporter Imapped to 135ps,running 9j Mugello alloys & low profiles.
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. Faulty Fuel/Temp Gauge
    By 16v_Golf in forum Archive posts
    Last Post: 24-01-2008, 01:30 PM
  3. Newbie - first post- looking to buy!
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  5. VOLKSWAGEN REVEALS HIGH TEMPERATURE FUEL CELL TECHNOLOGY
    Last Post: 01-11-2006, 09:55 PM
