Thread: 1.8 T deceleration rattle
  1. 1.8 T deceleration rattle
    Mar 2009
    I'm a Newbie on here - hello all.
    Recently purchased Treg passat estate seems to have developed a rattle when decelerating (may have been doing it before but only noticed it with windows open in warm weather!). As soon as foot touches throttle, the rattle disappears. Preliminary inspections suggests area around the turbo but I'm unfamiliar with these beasts.
    Has anyone got any ideas what it may be, if I would be able to fix it myself (reasonably mechanically able) , and costs.
    Thanks.
  2. Re: 1.8 T deceleration rattle
    It could be a loose heat shield plate,on the exhaust syatem
  3. Re: 1.8 T deceleration rattle
    Chester-le-Street, United Kingdom
    what sort of mileage are we looking at please?
    small ends spring to mind,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  4. Re: 1.8 T deceleration rattle
    Mar 2009
    Mileage is 106k.
    Noise definately coming from turbo area (listened with long screwdriver).
  5. Re: 1.8 T deceleration rattle
    Jul 2008
    Had the same a few years back.
    Mine was a worn waste gate arm. Which meant a new turbo.
    But the more common problem is a worn waste gate actuator. (Metal cylinder with a long rod comming out of the bottom.)
    When the engine is cold feed your hand through to the actuator & pull up on the bar that is attached to the waste gate arm. There should be a bit of effort needed to operate it, if you can!. If it's easy, then this is probably your problem.
    You can buy replacement actuators from: http://www.forgemotorsport.co.uk/con...2&catalog=1706, but it is a turbo out job!
  1. 2005 A6 Rear Brake Caliper Rattle
    By Steve Murray in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 06:48 PM
  2. front rattle problem, A4 1.8 T????
    By wipp5y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2008, 05:08 PM
  3. 1.8 20v top end rattle
    By siavant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-09-2007, 10:39 PM
  4. rattle from under a mk3 golf. (brakes maybe?)
    By Feemer in forum Golf MK3 - 1993 - 1999
    Last Post: 26-05-2007, 11:52 PM
  5. Golf 1.8 20v GTI rattle???
    By mervsilk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-03-2007, 03:49 PM
