Thread: Front Fog Lights
Results 1 to 10 of 10
  1. Front Fog Lights
    Dec 2006
    Has anyone actually done (DIY) an after-market front fog light kit to a B6 Highline (2008) (UK). Harness suppliers say recoding is required to get functionality on new switch. VW say it can not be done! I am confused! Help and/or instructions much appeciated.
  2. Re: Front Fog Lights
    Norfolk
    You have to ask vw what "onboard supply control unit" you have. They all have an output for rear fog light but apparently they don't all have a front foglight output. In theory you can check by looking at the connector pins. There are two out put 11 pin connectors. Black one needs pin 4 to work and brown one needs pin 2 to work. A good autoelectrician could get everything to work for you just bypassing the onboard supply control unit but that would be up to you.
  3. Re: Front Fog Lights
    Apr 2007
    France
    12 Post(s)
    There was a thread on here a while ago about them and the consensus was that they are a waste of time.
    The only time I've used mine was to check that they work.....
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Front Fog Lights
    Dec 2006
    Thanks, food for thought, but are yours a retro fit - and if so how?
  5. Re: Front Fog Lights
    Dec 2006
    Thanks, just tell me where it is and I will have a look!
  6. Re: Front Fog Lights
    Jul 2007
    Yep, the front fogs look pretty but are an utter waste of time.
    If I didn`t already have them I certainly wouldn`t contemplate fitting them.
    If you already have the units, just stick `em in, don`t bother with the wiring, as they are only for show - and they are prone to breakage from stones etc.
  7. Re: Front Fog Lights
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by Colestation View Post
    Mine were part of the car's package, and they are generally reckoned to be a bit of a waste of time.
    Might be worth doing a search on here (B6) for foglights.
    1996 Laguna 2.2D
    1977 MGB roadster
  8. Re: Front Fog Lights
    Rutland
    Would not agree they are a total waste of time. Its just they only show any benefit when its real fog not the stuff which is really just mist. A few times a year we get really bad fog on on a high (for round here) road running across a flat plain. Dips just give a white wall but fogs on their own get right down low and illuminate the verges. You can't go more than 10-15mph but in those conditions thats enough.
    For retrofit try vwvortex. Its a common USA mod and I think there's a dedicated thread in the B6 forum.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  9. Re: Front Fog Lights
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by gamichea View Post
    That's interesting - we don't get much fog here so as I said I've never used mine. I was summarizing a previous thread.
    I should say that I had fogs and used them on my cars in the UK in just the conditions you describe. Must try to find some fog....
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: Front Fog Lights
    Nov 2008
    Lincoln, UK
    I agree with gamchea. Very rare occasions when fog lamps are really needed however. Far more occasions when they are just used as "poseur lamps" adding extra dazzle with dips on also. Not really worth the extra unless fitted as standard (or you want to pose!)
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  4. need to connect front FOGS to mk3 gti
    By cyrilp in forum Golf MK3 - 1993 - 1999
    Last Post: 25-11-2007, 11:17 PM
  5. How does the Quattro system work?
