Thread: Flashing Glow Plug Warning Light.
  1. Flashing Glow Plug Warning Light.
    Apr 2009
    I have an 1998 A6 1.9TDI and in the last two weeks the glow plug warning light has been flashing on and off. This has not been on a regular basis and only happens on longer journeys when I am doing more than 70 - 80 mph.
    Can anyone advise the cause behind this and what the best solution is?
  2. Re: Flashing Glow Plug Warning Light.
    Southern County Softy
    20 Post(s)
    Check your brake lights work...
    A4 2.5 tdi QS (mapped)
  3. Re: Flashing Glow Plug Warning Light.
    I agree, brake light switch
  4. Re: Flashing Glow Plug Warning Light.
    Mar 2009
    Brake light switch?
    I've just had the same happen on mine last night - will check the brake lights later then .....
    1 1 0
  5. Re: Flashing Glow Plug Warning Light.
    Jan 2013
    Leeds
    Had this happen to me this morning, read lots of horror stories on other forums/feeds
    after reading the above comment about brake light switch, went out to car switched ignition on and 'ragged' the brake pedal a few times, glow plug light went off and stayed off
    How pathetic!
  6. Re: Flashing Glow Plug Warning Light.
    May 2016
    Iataly
    What is the connection?
    I had my spark plug light go on so a French garage naively changed the plugs but the light stayed on. They ordered a brake switch but it arrived and was the wrong one. When I got to Italy they fitted a brake switch but the warning light stayed on. They said I really needed a clutch switch and ordered one but it is not yet fitted. Meanwhile, the gear box had started to spit out 6th gear, they said I needed a new gearbox. Then recently, I went out to the car and the spark plug light was no longer on, the brake lights were working and the gear box problem had disappeared!
    Anyone got a clue what is going on?
  1. Flashing glow plug light on 03 Ibiza 130 TDI sport
    By Maitland_78 in forum Ibiza - Cordoba
    Last Post: 10-04-2008, 04:45 PM
  2. Glow Plug warning light flashing problem
    By Mark Hunt in forum Audi A4 - Archive Topics
    Last Post: 23-09-2007, 07:31 PM
  3. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
  4. Glow Plug Warning Light Flashing
    By grange in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 01:04 PM
  5. Glow Plug Warning light
    By maniVW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-02-2007, 12:45 AM
