Thread: Tdi lazy starting when warm and short glowplug light
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
  1. Tdi lazy starting when warm and short glowplug light
    Hi all
    My golf 1.9 110 tdi has a few issues and Im thinking they could be related.
    When starting from cold it starts great but even if its been turned off for a few mins its a pig to start takes a good few seconds.
    Also the glow plug light is only on for a second??? hot or cold.
    Im a little down on power too with some ugly flat spots around the mid range.
    Ive recently replaced the gearbox,I replaced the glowplugs two months ago.
    Have i disturbed the starter and caused it a problem as it wasnt lazy starting when warm before i replaced the gearbox??
    Thanks Aaron
  2. Re: Tdi lazy starting when warm and short glowplug light
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by imortalmonkey View Post
    Hi all
    Thanks Aaron
    Did you ever sort out the 1 second glowplug light?
  3. Re: Tdi lazy starting when warm and short glowplug light
    Feb 2009
    Middlesbrough
    have you had a cambelt done recantly?
    with out dissapointment you cant appreciate victory
  4. Re: Tdi lazy starting when warm and short glowplug light
    Hi thanks for the relplies
    What I found is that I have a few things going on,The lazy starting is the starter motor and whats happening is the ecu is looking for the starter to be cranking quite fast and until it is it wont let the engine start,on cold start the ecu doesnt look for the rpm of the starter hence the quick start.
    Hope that made sense?!! glow plug light still goes out quick...hmmm. starts loads better now tho!!
    I think my power issues may be maf related as when i tap it with a spanner the idle speed changes!!! lol,it tops out at 103 mph and it used to do 119 mph.
    No cambelt change recently!!
  5. Re: Tdi lazy starting when warm and short glowplug light
    Feb 2009
    Middlesbrough
    have you got a new starter motor or? i notied some times mine spins over quicker than other and when it does it starts quicker, i was wondering if it was the battery
  6. Re: Tdi lazy starting when warm and short glowplug light
    Quote Originally Posted by tdigolf View Post
    with mine i stripped it and lubricated it, just gave it a bit of an overhaul and its loads better,may buy a new one if it goes back the way it was!!
  7. Re: Tdi lazy starting when warm and short glowplug light
    Chester-le-Street, United Kingdom
    [QUOTE=imortalmonkey;352733]Hi thanks for the relplies
    not at all
    why would it look for crank speed?
    crank direction i can understand,but it can't control crank speed.
    if the battery's good,and the starter is good it will start faster because it cranks faster and the heat required under compression is generated faster.
    unless i have missed something,why does it look for crank speed when hot,
    but not when cold?
    regasrds,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  8. Re: Tdi lazy starting when warm and short glowplug light
    [QUOTE=STEWY L;353050]
    not at all
    but not when cold?
    regasrds,
    stewy.
    The ecu doesnt look at the starters crank speed when cold. However it does when warm.
    its looking for 2300 rpm from the starter if Iirc befor it allows fuel to be injected. Simples.!! Lol
  9. Re: Tdi lazy starting when warm and short glowplug light
    [QUOTE=imortalmonkey;353356]
    Quote Originally Posted by STEWY L View Post
    2300rpm from the starter motor
    some starter that is
    you will be lucky to see 500 rpm with a very very good battery and starter.
    don't know who told you 2300rpm,but he is a very dangerous mechanic to use if he believes that.
    i'm gob smacked
    regards,
    stewy.
    4th cog,--two to go
  10. Re: Tdi lazy starting when warm and short glowplug light
    Posted on here in many many posts. ok so i may be wrong on the speed but Im sure your arogance isnt required.
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. Sharan TDI Warm Start Problem
    By keithm in forum Touran - Sharan - Caravelle
    Last Post: 27-04-2008, 02:12 PM
  3. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  4. problems starting A4 2.5 Diesel (Quattro, 03)
    By seanpcashman in forum Archive posts
    Last Post: 21-01-2008, 03:43 PM
