Thread: Limp mode
  1. Limp mode
    Jan 2009
    So my car 03 GT TDI 130 Golf MK4, goes in to limp mode between 85-100mph, i know i dont often do these sorts of speed but i want it fixed as it can only lead to worse things.
    I had a fault scan done on VAGcom by some one i know and the fault that was identified was:
    17965 - Charge Pressure Control: Positive Deviation p1557 - 35 - 10 - - - intermittent
    So i have changed the N75 valve and still no luck, still going in to limp mode, I was wondering if any one else has got anything else to check before i have to replace the turbo.
    The car needs a service in 1900miles, and i am planning on getting this done over the next few weeks, could this cure the problem? just that it needs a good service?
    Any other suggestions will be helpful.
  2. Re: Limp mode
    Dec 2007
    New Mills, Derbyshire
    Possibly either Air Mass Meter, or the turbo. Before replacing the turbo (£XXXX!!!!), try the Innotec Turbo Cleaning kit.
    http://www.innotecworld.com/c-1057-turbo-clean-set.aspx
    You can order one direct from them, £37 ish.
    150 GTI DIESEL - propper juice!!
  1. A4 1.9 tdi in Limp Home mode after high power.
    By saidtheape in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2009, 01:10 PM
  2. Limp mode - think I'm going to cry!! lol
    By MikeMc in forum Golf MK4 - 1999 - 2004
    Last Post: 22-04-2009, 09:47 AM
  3. Strange limp mode
    By danielintheuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 09:35 PM
  4. tdi 130 lack of power and limp mode !!
    By BICCUS1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-10-2007, 08:05 PM
  5. 6mths HELP!!
    By RGC in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-07-2007, 10:44 PM
