Thread: A6 steering wheel replacement
  1. A6 steering wheel replacement
    Can anyone help with what steps I should follow to remove the steering wheel on my 2.8 SE 1998 A6.
    Is there anything special I need to do?
    AJO Guest
  3. Re: A6 steering wheel replacement
    Sep 2008
    Quote Originally Posted by AJO View Post
    I wish to fit a multi-function steering wheel with paddle shift to my car which has a standard Audi Sport steering wheel with no buttons on it.
    Has anyone done this successfully, as I would like to hear from you.
    My car is a Audi A6 (C5) with Tiptronic gearbox.
  4. Re: A6 steering wheel replacement
    Sep 2008
    "The Tiptronic steering wheel has two rocker switches that allow, when in Tip mode" -
    I thought you could change up and down on the steering wheel provided the lever was either in 'D' or to the right in Tip mode.
    This link says the paddles only work if the lever is in Tip mode.
    Which is it?
  5. Re: A6 steering wheel replacement
    Mar 2008
    High Wycombe
    I'd have thought it would only work in tip mode - in D, surely once you've changed, the automatic mode of D would change back to what it thinks is the best gear?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: A6 steering wheel replacement
    Jan 2021
    San remo Victoria Australia
    Mi hopefully someone can help me with me wanting to take the steering wheel I have in a doner car it has the gti style but no paddles and that is good im hoping because I am wanting to put it into my basic 2004 mk5 5speed golf that has basic steering wheel with no controls for stereo. So I was hoping that because same model mk5 that I would be able to change it over with stereo so I get nicer steering wheel with controls CAN IT BE DONE
    Sent from my SM-T515 using Tapatalk
  1. Steering wheel upgrade
    By Ben in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-08-2007, 07:48 PM
  2. MK5 GTI steering wheel
    By Hashhater in forum Golf MK5 - 2004 - 2009
    Last Post: 30-05-2007, 09:19 PM
  3. Steering Wheel badge
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-04-2007, 01:51 AM
  4. Steering wheel removal
    By nomisp1964 in forum Passat - Archive Topics
    Last Post: 11-03-2007, 11:47 AM
  5. Multifunction Steering wheel
    By jfh1 in forum Archive posts
    Last Post: 12-08-2006, 06:26 PM
