Hi all,
Been a member for a while but never posted before - just sculked around in the background........
For the past couple of days, my yellow ABS warning lamp has lit up whilst driving, along with a flashing red exclamation mark, along with 3 beeps when it first happens. It's a bit hit and miss when this happens and may not happen at all.
Anyway, I hooked up VAG-COM and it found 2 faults - one with the 'Intake Manifold Pressure Sensor (G71)' and the other with the 'ABS Wheel Speed Sensor: Front Right (G45)'.
On reading some similar posts, I removed the (front right) wheel and then removed the ABS sensor. I gave it a brief wipe with a brillo pad followed with a quick spray of WD40, before replacing it.
The warning lamps on the dash have not since reoccurred but VAG-COM still reports '30-10 - Open or Short to B+ - Intermittent'.
Can anyone offer any further advice? Should I ignore VAG-COM and wait til the warning lamps return?
P.S. can anyone confirm how I should have refitted the sensor? I pushed it in as far as it would go, but does the rubber ring around the sensor acts as a buffer/shock or should it have been placed around the female housing once in place? Am I making sense?
Anyone have any clues about the 'Intake Manifold Pressure Sensor (G71)' fault? It's reporting '28-10 - Short to B+ - Intermittent'?
Thanks in advance :-)
Dave
1996 Audi A4 (90bhp)
