Thread: Location of fuel cut out switch??
Results 1 to 9 of 9
  1. Location of fuel cut out switch??
    Apr 2009
    Apologies if already a thread but had searched and found nothing.
    The starter motor went on my 1.6 petrol golf, but we were able to get it running by bump starting until now.
    We got a replacement part from the breakers which turned out to be the wrong one (thanks guys!), as we had removed the old one, we left the battery and old starter motor out overnight, hoping the breakers would be open today to change the part.
    As they are not open we put the old one back on and tried to bump start the car. Now we can just about start the car but nothing happens when you put your foot down on the throttle, and then the engine cuts out. We are wondering if the fuel cut out swich has cut out?? And if so, where is it located to switch it back on??
    Have searched the boot thoroughly.. can't find it.. Anyone know whats happening?
  2. Re: Location of fuel cut out switch??
    Hi Vehicles with an airbag are fitted with a crash fuel shut-off. It reduces the danger of a fire in a crash as the fuel pump is switched off via the fuel pump relay.SO check your battery
  3. Re: Location of fuel cut out switch??
    Apr 2009
    Thanks Kenney,
    it's a new battery.. we couldn't find the fuel pump relay.. does this automatically switch off if the battery has been disconnected for some time? We think it's under the steering wheel, just checking haines manual.... is it worth taking out all the trim and checking the fuel pump relay?
  4. Re: Location of fuel cut out switch??
    It is only the airbag control unit,when deployed,that activates the fuel cut supply.The fuel pump relay is in position 4 on the relay carrier marked 409.You can run a positive feed to fuse 28 and listen if the fuel pump runs
  5. Re: Location of fuel cut out switch??
    Apr 2009
    Thanks again.. how do you run a positive feed.. do you need specialist equipment?
  6. Re: Location of fuel cut out switch??
    No you just run a wire from the + terminal on the battery
  7. Re: Location of fuel cut out switch??
    Apr 2009
    Thanks.. just ran the positive feed.. can hear the fuel pump working. Where do I go next??
  8. Re: Location of fuel cut out switch??
    You may have forgotten to connect something when you replaced the starter and the battery,since it started before hand.If you can not see anything obvious,then you will need a fault code read,for which you do need special equipment, and you probably will have to adapt the throttle body
  9. Re: Location of fuel cut out switch??
    Apr 2009
    Thanks again Kenney.. we gave up for today, and will double check in the am. Otherwise we will need to go over to the dark side, and ring the AA.... ho hum x
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. Touran 2.0TDi Non Starter, Fuel Cut off switch?
    By ccfc1987 in forum Touran - Sharan - Caravelle
    Last Post: 07-05-2008, 07:29 AM
  3. Please Help. Non Start - No Fuel Flow.
    By wallis22 in forum Archive posts
    Last Post: 13-01-2008, 03:10 PM
  4. Newbie - first post- looking to buy!
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
