Thread: Vag tacho key matching problem
Results 1 to 10 of 13
  1. Vag tacho key matching problem
    Mar 2009
    Hi everyone,
    I have bought vag tacho V2.2 and I have obtained my SCK 4 digits pin. But when I tried to adapt a new key, (followed the steps "Program new key" I entred my pin, Number of new keys 1 is already selected and I press ok then it says ok and it asks to disconnect, turn ignition off and back on with the new key and wait 5 seconds). I did and I was waiting for about 1min but nothing happened when I tried to start the engine with new key I says engine workshop....
    Anyone knows what are the correct steps to adapt new key using vag tacho V2.2. The car is passat 53 plate TDI Sport 130bhp.
    anyhelp will be appreciated
  2. Re: Vag tacho key matching problem
    Apr 2007
    Lancashire
    Was the key transponder new, as only 'virgin' unused transponders can be matched to immo3 cars. (around £7 non-trade)
    What immo dash lights/flashes occured when you first tried to match the key?
  3. Re: Vag tacho key matching problem
    Mar 2009
    The key was not virgin I bought it off ebay but it is exactly the same frequency and code. The iimmob orange light "car with key inside it" flashes alse the orange glow wire falshes too.
    Do u mean that I need to use the erase key option to make my new key virgin then program it?
  4. Re: Vag tacho key matching problem
    Apr 2007
    Lancashire
    The transponder chip/capsule inside the blade part of the flip-key needs to be brand new and 'unused'.
    Immo3 ignition transponder chips use a 'lock bit' and can only be matched to a single car.
    The remote 'button' half of the key will operate the central locking, but the immob transponder chip buried in the flip-blade part of the remote needs to be changed for a new one inorder for it to be matchd to the instruments/ignition and let you start the car.
    The best option may be to purchase a new flip/blade half of the remote containing a new transponder appropriate to your model.
  5. Re: Vag tacho key matching problem
    Mar 2009
    Thank you ini for your replies,
    The key came with a blank blade so I had to cut it at my local lock smith to match my car. So according to your comments I should be able to prgram it to my car? But the problem at the final stage of prgramming using vag tacho, it says to disconnect turn the ignition off and back on with the new key and wait 5seconds, when I do this the key is not programmed????.
    Anyone used vag tacho to program a new key?
  6. Re: Vag tacho key matching problem
    Hi Try this,Enter ECU and erase any fault codes,and erase stored values,then try and programme the key.
  7. Re: Vag tacho key matching problem
    Mar 2009
    I have cleared ECU errors (I dont know where to clear stored values In tacho) and I tried again, The new key started the car the first time but when I turned the engine off and tried it again It said immobi Activated engine workshop.... I dont understand Is it me, Tacho or the car???
    Please help I dont wanna give up and go to VW *******
  8. Re: Vag tacho key matching problem
    I'am not familiar with Tacho,but from experiance,with VAS,it can be sometimes problematic,to code keys when there is a fault logged in the ECU.However,clear the faults before programming any keys.The same applys to the dash insert.To clear stored values in the ECU,login engine management, 01 and go to adaption 10 and clear stored values 00.Then try to programme the key.
  9. Re: Vag tacho key matching problem
    Apr 2007
    Lancashire
    Where did the new key come from, and what car is it for?
    If the key was unused it should be ok.
    From you description, is it possible that it has a fixed code transponder (no crypto, just ID) for an earlier immo2 model inside the key?
  10. Re: Vag tacho key matching problem
    Mar 2009
    I have bought the new key from ebay and It was not cut so I presumed it to be new. But not entirely sure. (is there a way to know?)
    How do i check if it has a fixed code transponder? The only thing I know is the key code which is HLO 1JO 959 753 AH 434 MHz. and the blade was new when the key arrived.
  1. 2nd Key Fob Synchronisation
    By Tazdevil1977 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-02-2020, 10:59 AM
  2. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. How to change the key blade?
    By mrmonk21 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 01:15 PM
  5. Key Fob Problem 04 Passat
    By Riven in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-10-2007, 07:54 PM
