Thread: isofix on an 2005 a4 avant?
  1. isofix on an 2005 a4 avant?
    I don't see any isoxfix on my 2005 Avant, is that right? Any way to fit it?
  2. Re: isofix on an 2005 a4 avant?
    Jan 2009
    Quote Originally Posted by thecount View Post
    Many members have retrofitted Isofix brackets, as I have. From memory you will need the bracket (or two if you wish to do both sides) and two attach bolts. Your local dealer should be able to supply these.
    It is very easy to fit - lift the seat base out, then simply bolt in. You wil need a star drive socket for the bolts.
    If you do a search, there are photos on here.
    Cheers!
  3. Re: isofix on an 2005 a4 avant?
    thanks, will do.
  4. Re: isofix on an 2005 a4 avant?
    well, I called my local dealer, and they quoted aprox £200? is that really the cheapest option here?
  5. Re: isofix on an 2005 a4 avant?
    Jan 2009
    Is that £200 for the bracket and bolts? Mine cost about £40-£50 from Audi about a month ago! 10 mins to fit.
    It shouldn't be too hard to find the correct part, I walked in and within minutes the correct parts were ordered, then I picked them up the next day.
    If you get really stuck, I would dig out the invoice, assuming that they are exactly the same parts - mine is a 2005 Audi A4 Avant 2.0 TDi S-line.
  6. Re: isofix on an 2005 a4 avant?
    not sure if that was fitted or not. Would I need to drill any holes, or are they already there?
  7. Re: isofix on an 2005 a4 avant?
    Mar 2008
    Just Cumbria now.
    The holes should be pre -tapped, i.e. with the fixings already in place.
    Look in this thread for clues, it's for a Passat, but should be very similar.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=33977
    HTH
    Nothing to see here, move along..
  1. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
