Thread: Replace the small speaker beside the wing mirror
  1. Replace the small speaker beside the wing mirror
    Mar 2009
    2001 TDI SE. There is a small speaker on the front door on the inside of the wing mirror. One of these has blown. Has anyone changed theirs and if so where do I get a replacemnt from, cost and how difficult is it to change?
  2. Re: Replace the small speaker beside the wing mirror
    Jun 2006
    UK, Mids
    Either dealer, scrapyard/ebay or if you want third party, http://www.pioneer.co.uk/uk/products...703/specs.html
    are a high-quality supposed direct replacement of factory speakers for around £60.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Replace the small speaker beside the wing mirror
    Jul 2008
    In order to replace the "tweeter" you will need to take the door card off. There are 2 screws (I think) on the bottom of the door card which uses a hex or allan key. There are 2 more phillips head screw on the inside of the door handle. For this you will need to take the grab handle cover off, but be careful because the plastic is fairly easy to scratch and damage. From there it is plain sailing - you will need to disconnect the locking mechanism and the electrical connections. The tweeter cover should them pull off and the speaker itself is shrouded in polystyrene.
  4. Re: Replace the small speaker beside the wing mirror
    Mar 2006
    Quote Originally Posted by essexexpat View Post
    Hello
    I changed mine with some tweeters from Maplin. You have to trim the surround a bit but to be honest you have to replace the whole lot if you getting a new set. They sound perfect.
  1. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Replacing passanger side wing mirror on 1998 Golf Cabriolet
    By mariag in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 01:03 PM
  4. Replacing a Broken wing mirror on a Sharan (housing and all)
    By JReed in forum Touran - Sharan - Caravelle
    Last Post: 12-12-2007, 10:34 PM
  5. A4. How d'you replace a wing mirror ?
    By PeterT in forum Audi A4 - Archive Topics
    Last Post: 23-10-2007, 05:10 PM
