Thread: clutch fails when brake pressed
  1. clutch fails when brake pressed
    Apr 2009
    I have replaced clutch, slave cylinder and master cylinder in jan 09 today same problem again, when brake and clutch are pressed together the clutch biting point goes to the floor and stalls engine and clutch stays on the floor until iI pull it up by hand and as long as I dont touch the brake the clutch works fine. please help!
  2. Re: clutch fails when brake pressed
    131 Post(s)
    1978 Post(s)
    Which year and engine?
  3. Re: clutch fails when brake pressed
    Apr 2009
    03 tdi 150
  4. Re: clutch fails when brake pressed
    131 Post(s)
    1978 Post(s)
    Well Golf 4 master and slave cylinder failure are very common but as you have replaced both, the only connection I can see is the fluid supply from the reservoir on top of the brake master cylinder which also supplies the clutch. If the fluid level is correct and there is no air in the system, one of the new components is faulty and with those symptoms I would suspect the clutch master cylinder. Where did the master and slave come from? I hope that it isn’t the slave cylinder that is faulty!
  5. Re: clutch fails when brake pressed
    Apr 2009
    Thanks for your reply Crasher all levels of fluid are fine and there does'nt seem to be any air in the system when it is bled the gear box went at christmas and I had it repaired. While the gear box was out I had a new clutch put in and a slave cylinder, several days later this problem started so I had the master cylinder changed which solved the problem but unfortunately 3months later (yesterday) the same problem has ocurred. From what you have said and my experience it points to the master cylinder again would you agree. Is there any other reason why the master cylinder would fail again as the original master cylinder lasted for 6 years without a problem. Many thanks again Crasher
  6. Re: clutch fails when brake pressed
    131 Post(s)
    1978 Post(s)
    It depends on where the parts came from. I have seen white box unbranded pattern slave cylinders fail before the car even leaves the workshop. What make were the parts?
  7. Re: clutch fails when brake pressed
    Apr 2009
    I am not sure what the parts are but I will find out. Thankyou.
  1. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  2. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
  3. Brake & or Clutch Problem
    By mountaintiger in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2008, 09:28 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Replies: 2
    Last Post: 11-05-2007, 12:30 PM
