Thread: Passat High Idle.
  1. Passat High Idle.
    Apr 2009
    Mayo, Ireland
    Hi all,
    I have a '97 1.6 petrol passat - the first of the newer shapes. Anyway, recently it has started to idle very high (around 3400rpm) after a few minutes driving, before the engine gets up to operating temperature. I checked for any air leaks, but can fault none of the pipes.
    I got the loan of a code reader today and it came up with
    "00515 Hall Sensor G40"
    Looking around the internet, including this site, it seems to be the cam sensor - I didn't think a cam sensor would be able to throw the idle off as much as that though!
    Has anyone had similiar experience?!
    Thanks in advance.
  2. Re: Passat High Idle.
    Norfolk
    The hall sensor tells the ecu about cam timing so the wrong signal could lead to poor running. A vag-com read will give you 00515 plus a better desription of the fault e.g. open circuit, wrong resistance etc. The test is to replace it with a known good one. Easy if you happen to have a mate with the same car. Guess you may have to buy one to find out.
  3. Re: Passat High Idle.
    Apr 2009
    Mayo, Ireland
    I didn't think it would cause the engine to idle so high though! It takes a bit to start is, which is understandable.
  1. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  2. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. The Passat Bluemotion – Uk Market Information
    Last Post: 02-05-2007, 07:28 PM
