Thread: Recirculation motor
Results 1 to 10 of 10
  1. Question Recirculation motor
    Oct 2006
    Sunny slightly hilly Norfolk
    I've just had the common recirculation motor problem. I've been quoted £470 by my local ******* to replace it (its the dash out one!). This is cheaper than I was expecting but has anyone else had this done and at what cost?
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  2. Re: Recirculation motor
    Jul 2008
    Thats cheap. Must be the credit drunch. They were quoting nearer £900 last year for the same job. Easier just to take out pollen filter, push the flap into the open position, replace filter, jobs a goodun..
  3. Re: Recirculation motor
    Oct 2006
    I've tried that but every time I turn the engine on, it just goes through it's self check and the clicking comes back! Looks like I'm going to try to do it myself!
  4. Re: Recirculation motor
    Jun 2006
    UK, Mids
    I swear there was a write-up on here by a man who found he could do it without taking the dash out.
    EDIT maybe it was the blower motor, I have had a good search.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Recirculation motor
    Jul 2008
    Push it open harder...
  6. Re: Recirculation motor
    Oct 2006
    Don't want to do that as round here, its handy to block some things out!
  7. Re: Recirculation motor
    Jul 2008
    Oh go on - I live in the same County as you and I put up with the sewage smell on the A47 Whittlingham bridge
  8. Re: Recirculation motor
    Oct 2006
    Now that is quite pleasant compared to some of the stuff they put on the fields near here!
  9. Re: Recirculation motor
    Oct 2006
    Right I've bitten the bullet, got the Haynes manual out and a new motor. What Haynes DON'T tell you is........ you have to get the air con/ Climatronic drained as to get the heater assembly out, you have to disconnect the air con pipes in the plenum chamber. Anyway after much swearing and other stuff, I got the motor out only to find......... the new one is wrong and the part numbers don't match! After looking on Vagcat and putting in the right number do I find that there are several different ones! So I'm left with all of the dash out and no car for work Monday! I guess I'll have to get the cycle out which is good for me apparently and at least the weathers ok! I'll keep you posted!
  10. Re: Recirculation motor
    Oct 2006
    Ok, its all sorted and back in! Its a pig of a job but at least I found that the fan was broken too so saved the cost of a genuine one had I got the dealer to do all this. New fan is £227 apparently. Ouch! Fan from GSF is £48.50 delivered, much better. All I need to do now is get the fault cleared from the Climatronic to stop the display flashing on start up unless theres a different way?
  1. No fan 99T A4-B5 tdi
    By Jabez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2013, 10:08 PM
  2. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  3. recirculation motor
    By glynnd in forum Passat - Archive Topics
    Last Post: 18-07-2007, 11:48 PM
  4. heater fan problem
    By doc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2007, 02:01 PM
  5. Unlockable boot
    By steve1980 in forum Passat - Archive Topics
    Last Post: 21-08-2006, 10:22 PM
