Thread: Clutch pedal dropped to floor
Results 1 to 8 of 8
  1. Clutch pedal dropped to floor
    Dec 2008
    Newark on Trent
    Well I just got back from having my 1990 Golf Driver recovered as I was coming upto a roundabout and pressed the clutch to change down it gave way and dropped to the floor.
    I managed to keep it going long enough to get me into a lay-by - could change up n down with force and it would drive ok so don't think its the clutch itself - but when I did stop it wont select any gear - it tries for reverse and starts bunny hoping backwards a little.
    Having a look around from other forums - it sounds like either the pedal assembly or clutch cable.
    Anyone had this problem or know how easy it is to fix???
    John
  2. Re: Clutch pedal dropped to floor
    131 Post(s)
    1976 Post(s)
    It should be the cable; they take about half an hour to do.
  3. Re: Clutch pedal dropped to floor
    Dec 2008
    Newark on Trent
    Ah nice one - Cheers for that.
    Only got it last week so came as a suprise but just ordered myself a Haynes Manual of ebay for it too
    Thanks again
  4. Re: Clutch pedal dropped to floor
    131 Post(s)
    1976 Post(s)
    If you get stuck, Paul Smart of Smart VW’s is in your area.
  5. Re: Clutch pedal dropped to floor
    Dec 2008
    Newark on Trent
    Yea nipped down there just the other day for a quote on a waterpump
    Fancy having a go at the clutch cable myself - bit of a novice but I don't need the car in a rush so can take my time over it
  6. Re: Clutch pedal dropped to floor
    131 Post(s)
    1976 Post(s)
    Non power steering water pump is easy, half an hours work, PS makes it much more involved.
    Just shout out if you need help, I am only just down the road.
  7. Re: Clutch pedal dropped to floor
    Dec 2008
    Newark on Trent
    Cheers mate - thanks for your help
    Greatly appreciated.
  8. Re: Clutch pedal dropped to floor
    Dec 2008
    Newark on Trent
    All sorted now - your right it was as easy as pie!!
    Literally did take me 30 mins - the hardest and longest bit of the job was getting the little bung to sit in the engine bay bodywork right lol.
    One thing I did notice from the experience - the clutch cable is made by the french.....that speaks volumes :P
    Cheers for the help.
    Onwards to the water pump...........
  1. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  2. clutch pedal problem
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2008, 09:04 PM
  3. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
  4. Clutch pedal dropping
    By VOLKSWAGEN007 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-11-2007, 11:18 PM
  5. Clutch pedal over centre spring?
    By Bikerman in forum Golf MK3 - 1993 - 1999
    Last Post: 18-10-2007, 09:43 AM
